I am looking for sensors for monitoring air and water pressure in storage tanks and lines.· I can't seem to find any sensors like those on the Parallax site.· Any help appreciated.·
Thanks for the link. What I really need is something that can plumb into a compressor line/tank and one to plumb into a water line/tank. Any ideas for that?
Motorola (now FreeScale) make fine sensors.· SenSym (now Honeywell) makes an excellent series of gage, differential·and absolute pressure sensors, as does Honeywell under their own name.· All can be found in a variety of form factors, fluid/gas resistance and various temperature compensation/signal conditioning options.··Pressure sensors·are in·section 'N', pp 1223-1226 (catalog TO41, April '04) of the Digi-Key catalog.· Beware that·pressure sensors·are expensive, very intolerant of reverse polarity connections and·sensitive to pressure excursions beyond the rated limit (and I'm not talking burst pressure- get close to that, and they will never be accurate again).· Good luck and have fun.
I was suprised at the price of the pressure sensors I did find ($300-$500 range) and thought I must be missing something. What I am trying to do is monitor water and air pressure to make sure water pumps and compressors are working at remote locations. I am not that concerned with accuracy. Is there a inexpensive solution if I forego accuracy? Thanks.
Much of the price is determined by the form factor (30 pitch British Pipe Thread), the casing (314-L medical grade Stainless), fluid contact surface (all teflon membranes) and pressure range (>100 psig).· If you want a screw-in solution·to measure 300 psig of a corrosive fluid, you are gonna need to fork over a couple of vital organs.· If you are willing to do your own plumbing, are working in the 0 to 10 psig range, and are measuring air or water, a 15 dollar sensor will do the trick.· Take a look at what digikey has to offer.· If nothing suits your needs, contact me offline and I will hook you up with something that will do the trick.· We use LOTS of them for low pressure air and water measurement.
I am measuring in water and air in the 0-100psi range. I suppose 1/4" thread would be the easiest case to work with, and they appear to have those. I think with the basic 2 stamp I need 0-5vdc output. I looked at the digi-key catalog and it looks like I am can use one of there sensors, but they are still around $100 each (and I need several). Wow, I assumed they would be in the $10-$20 range. I suppose pressure switches might be another approach since I am trying to use it to tell me when pressure drops below a certain level to indicate problems with pumps and compressors. Although it would be nice to monitor actual pressure values.
I am not familiar with·VDO Oil Pressure Senders, but for $18.19 you can get a Motorola MPX5700GP-ND (digikey number) that will measure to 101.5 psig and give you a 0- 4.7V output.· You will have do do a bit of plumbing, as it is a barb fitting rather than NPT/BPT/compression.··A screw-in solution would be ideal, but if you only have 2 or three to do, it might be worth it to save 250 dollars.
Motorala MPXA4110A
Hope that helps!
http://www.freescale.com/files/sensors/doc/data_sheet/MPX4100A.pdf
peter
Dr. Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
peter
peter
spence
k4kep
i found this site in a minute or so just to demonstrate the product and not to reccomend a specific retailer
my company buys and installs hobbs switches to monitor vital engine systems; i.e. oil/water pressures in cost sensitive situations
i·think they are sold preset to a specific pressure set point.
also with contacts you can supply your own·voltage signal which is a major plus if line losses may be a problem.
roxon
nick bernard
