Tone Decoding
greetings guys!
I'm trying to figure out the best way to do some simple audio tone decoding.
I want to decode the audio of a fire dispatch.. Maybe you've heard them, maybe you haven't.
I'm really trying to avoid having a 567 (or another Phase Locked Loop of some sort) with component values setup to decode every single possible frequency.
The first problem I have to overcome is that I don't even know the exact frequency values of the tones, but I could probably get them by the time I'm ready to build this thing.
I'm wondering if there is a digital (more like analog) IC that will do some basic "frequency counting", and give me digital input that I can process from there? Failing that - what's the most efficient way to have 15-20 independant tone decoders wired to the stamp??
Thanks!
- Joel
Thanks!
- Joel
I remember that each tone is fairly long in duration.
Terry
1. Wait for first tone
2. Delay -- allow second tone to start
3. Second tone detected? If no, go to 1
4. Delay -- allow third tone to start
5. Third tone detected? If no, go to 1
6. Process alarm
Jon Williams
Dallas Office
Mr Williams: ok - Your idea seems sound (no pun intended), but I'm wondering if there are some examples of source code that already exist in a Nuts-n-Volts article or something. I'm not sure how I'm going to turn an audio signal (that just came through a headphone jack, so it's hot.. hot.. hot) - into a TTL level square wave. Know of any example schematics that I can modify to suite this application?
Bean: The COUNT instructions definately looks like it'd work - in this area most fire tones are over a second in duration.. From there the number of "transitions" would roughly be my tone frequency.. and with a bit of calibration, it'd be able detect them just fine.. Am I correct? So the same question still applies though, how do I get something that just came through a speaker output, and off the secondary of a small audio transformer - into the Stamp without frying it??
Thanks guys! I'm not trying to get you to design this for me.. I just have no idea what I'm doing in this particular instance.. and lots of others. [noparse]:)[/noparse]
- Joel
Jon Williams
Dallas Office
I believe that you wanna go the other way around -- audio into Schmitt trigger to bring the waveform into the digital domain and then run that Schmitt's output into a divider to get a nice....
Nah, if it's a fairly pure tone then you'll be getting a decent digital wave that could be measured by the COUNT function. No real need to run it thru a divider to get 50% duty square wave, now is there?
-Rusty-
Rusty Haddock = KD4WLZ = rusty@fe2o3.lonestar.org
**Out yonder in the Van Alstyne (TX) Metropolitan Area**
Microsoft is to software what McDonalds is to gourmet cooking
Jon Williams
Dallas Office
