Director Xtra to BS2
I'm having much trouble with communicating from Director (using SerialXtra). I've create a simple LED on the basic stamp to light up when the code recieves a letter such as "1". It works within the basic stamp software, but when I send from director nothing happens. I think the problem is the baud or something that keeps the two from communicating, maybe the pin setting. Does anyone have the code for both basic stamp and director to do this simple task. I have found a couple of examples but code is not complete and I have to guess at some of the settings. This should be easy, but I'm having a·bad time of it. Thanks in advance.
darryl
I'm using the basic stamp of education with the provided serial cable db9, I'm using the serial port on a laptop. I'm using Director MX with the SerialXtra plug-in.
Here is the code I'm trying to get working:
Director code:
exitFrame
put "start movie"
openxlib "serialXtra.x32"
serialObj = new( xtra "serialXtra")
if objectP(serialObj) then
serialObj.writeChar("1")
put "open the object"
serialObj.openPort("COM1")
if serialObj.IsPortOpen() then
put "object is open"
serialObj.setProtocol(9600,"n",8,1)
end if
end if
serialObj = 0
closeXlib
end
Basic Stamp code (I borrowed from a forum·example):
'{$STAMP BS2}
'{$PBASIC 2.5}
rpin CON 16
bmode CON 16468
maxtime CON 10000
test VAR Byte(3)
Main:
SERIN rpin,bmode,maxtime,timeout,[noparse][[/noparse]DEC test]
IF test = 1 THEN turnOn
'PAUSE 3000
GOTO main
timeout[noparse]:D[/noparse]EBUG"Timeout", CR
PAUSE 1000
GOTO main
turnOn:
HIGH 14
GOTO main
darryl
Director code:
exitFrame
put "start movie"
end if
end if
serialObj = 0
closeXlib
end
'{$STAMP BS2}
'{$PBASIC 2.5}
rpin CON 16
bmode CON 16468
maxtime CON 10000
test VAR Byte(3)
Main:
'PAUSE 3000
GOTO main
PAUSE 1000
GOTO main
turnOn:
HIGH 14
GOTO main
