Is concurrent use of serial port on BS2 for programming & app possible? Limitat
I have not worked with my Stamp for a year or so but have a new potential app.
My application would use all 16 I/O's plus I would need the serial port to submit simple (<16 characters) commands and receive simple (several characters) status replies.· Could/would my application use the same screen (debug screen?) that the serial port is normally connected to?
What limitations occur when using this same port for programming, debug functions, and application communication?
I just discovered your forum here (very nice!).· I have read some of the past posts on this subject.
If you could point me to sample code or documentation that would be great!
Stephen
Stephen
Hi Stephen,
If you put two applications, the programmer/debugger and a PC program, on one port you will have to switch when you use one or the other. It is doable but you will have to close your programmer/debugger each time you want to use your application and vv.
You just run two applications on one port. Things would be easyer if you could free two pins on the Stamp for a second communication link. Maybe only on a temporary basis.
Klaus
Jon Williams
Dallas Office
What is the easiest way to add the needed hardware for a 2nd rs232 port (I've seen a Maxim tranceiver chip mentioned).
-Stephen
In fact there are at least two easy ways to connect a PC to Stamp pins:
1 Use a MAX232 adapterboard, Al Williams sells them: www.al-williams.com
2 Go for USB. The USB2SER works fine for me and Parallax sells them. And...., you won't need an extra Com port
Succes,
Klaus
