Baudrate Setting in Programming for Serial Out
I had a Basic Stamp processor BS2P40 and 5 unit of AImotor(Servo Motor). The AImotor is interface in a TTL via a Translator circuit built from max232. The baudrate for AImotor can only transmitted between range from 9600bps to 11.5kbps. I had tried command like Serout, baud, [noparse][[/noparse]$00FF] and Pulsout Servo, $00FF as perference to the AImotor's protocol as it is communicating in a 8bit serial in/out.
I would like to check if the baudrate I input to my program as in "Baud CON 240" is correct?
The hardware wiring from my Basic Demo board to the translator(Max232) circuit are:-
(a) A pin P0 from Demo Board of BS2P40 as an output serial data to my Max232 pin 13 (Tx of PC or in this case Tx of BS2P40).
(b) A system common ground from Vss of Demo Board of BS2P40 to my Max232 pin 15 (gnd).
Please advice, thanks.
Mark
Mark
Jon Williams
Dallas Office
Attached is my basic program.
