PCtoBS2 using visualbasic
Hello everyone,
I try to communicate from my PC using VB program to BS2, I already read the nuts and volts article
Column #41, July 1998 by Jon Williams:
I am not able to have a link between PC and BS2 somebody have better codes or tutorial
Thank you
Thank you
http://www.parallax.com/detail.asp?product_id=29120
Jon Williams
Dallas Office
Al Williams
AWC
Stamp FAQ
http://www.wd5gnr.com/stampfaq.htm
See the attached.· It's as small and simple as I could make it,
with full examples on both sides.
You DO need VB5 Pro or VB6 Pro, as these are the only ones that
come with the MSCOMM control that VB uses.
