BS2sx SERIN command.
Hello,
I am programming a BS2sx board to acept values from a serial port and got a few questions:
1) I need to make a FOR loop where variable M will go fom 1 to 5 (for example)
and inside the loop i need the SERIN command to WAIT for "po:" M
so in the first execution of the loop it will wait for "po:1", second execution "po:2"
2) How long do the SERIN and WAIT commands take?
if i have these two commands in a row
SERIN 16,240,10000,NoData,[noparse][[/noparse]WAIT("r_cnt:"),DEC2 ErrCnt]
SERIN 16,240,10000,NoData,[noparse][[/noparse]WAIT("m_poi:"),DEC temp]
and i send data "err_cnt:03 err_elm_poi:4" will the BS have enough time to write 03 to variable ErrCnt and execute the next SERIN command in time to catch "m_poi:" and write 4 to variable temp?
Thank you,
Boris.
Thank you,
Boris.
SERIN 16, 240, 10000, No_Data, [noparse][[/noparse]WAIT("r_cnt:"),DEC2 ErrCnt, WAIT("m_poi:"),DEC temp]
Jon Williams
Dallas Office
Any thoughts on my 1st question?
· FOR idx = 1 TO 5
··· idx2 = idx + "0"
··· SERIN Sio, Baud, [noparse][[/noparse]WAIT("po:", idx2), pos]
· NEXT
You can't use the DEC output modifier in the middle of the WAIT parameters, so the line before SERIN converts the value of idx to ASCII.
Jon Williams
Dallas Office
seems that this trick only works for values 0 to 9, how would i convert string value "14" to decimal 14?
· FOR idx = 1 TO 5
· NEXT
Thank you,
Boris.
