Sump Pump Monitor
Need some assistance from the group...
My latest project is a Sump Pump Monitor.··I want to monitor how often and when the sump pump runs.· Figured I would use a BS2E for the microprocessor but looking for a safe and reliable way to figure out if the pump is running.·
Was thinking about·using a·current to voltage transformer on one of the 120vac legs and then monitor the voltage.·The float switch is integral to the pump and don’t want to void the warranty by rewiring it.
Looking forward to your ideas.··
Thanks.
/Tom
Thanks.
/Tom
if you check one of the other threads in the BS2 forum (I think it's high voltage/current monitoring...or something like that)...you'll see that Bean hooked up a Neon bulb to one of his 120Vac systems and just used an opto on the other side to measure the light (I believe he made it isolated from outside light with a box!).
anyhow, this is the least intrusive way to directly measure the pump operation.·
You CAN get more fancy and use vibration sensors or Hall effect sensors on the motor....
Steve
http://members.rogers.com/steve.brady
http://www.geocities.com/paulsopenstage
Sounds interesting. While you've got the horsepower of the Stamp there you could step it up a notch. You could hook up a cheap pressure sensor and hook it to a tube submerged in the sump. By monitoring the pressure readings, you could determine how fast the sump fills and when it empties. You may even want to correlate the info to rainy days and dry days. Just a thought.
Lee
Just a thought...
Bruce
Bruce Clemens, CET Sr.
Instructor, Electronics and Computer Repair Technology
Ozarks Technical Community College
www.otc.edu
