solid state sensor
In a message dated 7/22/2004 5:55:35 PM Eastern Daylight Time,
fredit@c... writes:
> All I would do to interface it to a bs2 is, I would put a 10k pull up
> resistor hooked up to the data line (dataline, ground,power)
> and put the bs2 pin high and everytime the sensor is triggered, It will pull
> the pin low, right?
I would think that you would make the pin an input and pull it high. If you
set the pin high, then a low will simply short the pin and smoke your Stamp.
Sid
fredit@c... writes:
> the pin low, right?
Sid
http://content.honeywell.com/sensing/prodinfo/solidstate/catalog/c20008.pdf
the pin low, right?
thanks for any help_Lee
