need help with SERIN for DS1302 application
Hi everyone,
I'm working on my voice-activated clock design. Basically, it has a
voice chip, a basic stamp 2 and a time chip DS1302. I'm trying to
send the time data (in hex) into the BS2+DS1302 to reset the time of
the clock. This is the code that I use:
Loop0:
SERIN 4, 84, [noparse][[/noparse]HEX1 Hours.HIGHNIB, HEX1 Hours.LOWNIB, HEX1
Minutes.HIGHNIB, HEX1 Minutes.LOWNIB]
Temp = Hours
RTCCmd = HrsReg
GOSUB WriteRTC
Temp = Minutes
RTCCmd = MinReg
GOSUB WriteRTC
DEBUG HEX2 Hours,":", HEX2 Minutes
GOTO Loop0
WriteRTC:
'Write to DS1202 RTC
HIGH RTCReset
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%10\2,Temp]
LOW RTCReset
RETURN
But seems like the BS2+DS1302 doesn't recognize the time data
transferred in.
I'm new to PBasic, I would really appreciate any help/idea.
Thanks.
Loop0:
Temp = Hours
RTCCmd = HrsReg
GOSUB WriteRTC
Temp = Minutes
RTCCmd = MinReg
GOSUB WriteRTC
GOTO Loop0
WriteRTC:
HIGH RTCReset
LOW RTCReset
RETURN
transferred in.
Thanks.
allan.lane@h... writes:
> The 1302 uses 'BCD' -- that is binary coded decimal.
> This means the HEX value it accepts goes from
> 0x00 to 0x09, then 0x10 through 0x19. So you have
> to convert from binary to BCD.
I use nothing but HEX - no BCD - and my 1302 works just fine.
Sid
is the first place that comes to mind for me.
-- Jon Williams
-- Dallas Office
From: amser99 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Fi0yTvdk0RF6xRYc7B-VxRmNjW70_45Ry3KBNJp3gf680nm_Pfya80lmBr4DRd69Us6XuwRlbH8W]amser99@y...[/url
Sent: Wednesday, July 21, 2004 11:16 PM
Subject: [noparse][[/noparse]basicstamps] need help with SERIN for DS1302 application
Hi everyone,
Loop0:
Temp = Hours
RTCCmd = HrsReg
GOSUB WriteRTC
Temp = Minutes
RTCCmd = MinReg
GOSUB WriteRTC
GOTO Loop0
WriteRTC:
HIGH RTCReset
LOW RTCReset
RETURN
transferred in.
I'm new to PBasic, I would really appreciate any help/idea. Thanks.
byte as an ASCII representation of a hexadecimal digit (as opposed
to a hexadecimal digit), and to convert and store accordingly. Is
that consistent with what your external device is sending?
I'd suggest a couple of DEBUG statements after the SERIN so you can
see what values are actually stuffed into your Hours and Minues
variables.
You could also try storing some hard-coded, you-pick-em values into
the '1302's hours and minutes registers to see if they are
stored and reported correctly.
Without seeing the rest of your program (variable declarations, etc.)
it's hard to divine where things may be amiss.
Steve
On 22 Jul 04 at 4:15, amser99 wrote:
> Hi everyone,
> Loop0:
It has a complete and working program for using
the 1302.
Gotchas: the 1302 uses SHIFTIN/SHIFTOUT to send data,
you MUST use the correct MSBFIRST settings.
(in other words, a decimal value of '10' is stored
in the BS2 as 0x0A. You have to convert that to
0x10 before sending it to the 1302.)
--- In basicstamps@yahoogroups.com, "amser99" <amser99@y...> wrote:
> Hi everyone,
of
> Loop0:
> Temp = Hours
> RTCCmd = HrsReg
> GOSUB WriteRTC
> Temp = Minutes
> RTCCmd = MinReg
> GOSUB WriteRTC
> GOTO Loop0
> WriteRTC:
> HIGH RTCReset
> LOW RTCReset
> RETURN
> transferred in.
> Thanks.
using four bits to represent a decimal digit, 0 - 9. To represent the
decimal value 99 in BCD, it would be $99 -- the upper nibble is the tens
digit; the lower nibble is the ones digit. So, in PBASIC we use the can
use the HEX modifier for BCD values.
Converstion (byte values, 0 - 99):
bcdVal = (decVal / 10) << 4 + (decVal // 10)
decVal = (bcdVal.NIB1 * 10) + bcdVal.NIB0
-- Jon Williams
-- Dallas Office
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IR9dPlTEEV3DWtLqga8d3hVS8IbdAYq4-JPfMhMLbMM5eRHAkI8E31T65suE0LYJbXk4q17Q_g]Newzed@a...[/url
Sent: Thursday, July 22, 2004 9:25 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: need help with SERIN for DS1302
application
In a message dated 7/22/2004 10:09:00 AM Eastern Daylight Time,
Sid
