CRC and the stamp
Just wondering if anyone has tried to implement a CRC using the
stamp? I am using a 2sx. Is it capable of the math? I have N&V's
article on it but would like to find an example.
I have a wireless application working (remote relay actuator) but
would like to improve error correction/rejection.
Ian
Ian
Stamp list as well. Here's a bit of code I used in a Stamp-to-PC
program:
Calc_CRC:
crc = (crc & $FF00) | (aByte ^ (crc & $FF))
FOR idx = 0 TO 7
IF (crc.BIT0 = 0) THEN
crc = crc >> 1
ELSE
crc = (crc >> 1) ^ $A001
ENDIF
NEXT
RETURN
The crc value is initialized to $0000 before looping through the bytes
in the package, sending them one at a time to the Calc_CRC routine.
I'll post the other demo in the file section as that algorithm was
described and provided with a small packet and expected CRC (and yes,
the PBASIC implementation works).
-- Jon Williams
-- Dallas Office
From: iphillipsca [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2xvQia5ksFZn_Br3ocil3WSH-q4p1VHwjXDNuenCDwPNLE4aaG__7A868EyXykaQBw0kdfqDh7regO7Ncg]iphillips@s...[/url
Sent: Wednesday, July 21, 2004 8:05 AM
Subject: [noparse][[/noparse]basicstamps] CRC and the stamp
Ian
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Parallax shines through.
Ian
and now a couple of questions.
Will this work the same if I just replace the TstStream data with my
byte to be sent? The code you posted would be just used to decode a sent
byte correct? To encode the crc I would have to alter the Subroutine, I
think.
I am using a 165 shift register to read switches and send to another 2sx
and if the byte is true, output a HIGH to a pin.
Sorry to drag on about this. I am starting to get the programming stuff
down, but I was never that good at math.
Ian
the "rules" as were presented by a customer. The input he provided
resulted in the proper output, which should prove the CRC generation
subroutine.
You do not need to alter the subroutine.
What you will do is initialize the CRC, then, one byte at a time, send
your "packet" to the subroutine. At the end you'll have a two-byte CRC
value that you can append to your packet to be sent. You receiver Stamp
will take the packet and run all but the last two bytes (appended CRC)
through the same subroutine. It will then compare its local CRC value
with the one appended to the packet. If the values match then there was
no problem. If they don't match, your protocol needs some method of
alerting the transmitter to resend the packet.
And I don't quite understand your application. If you're only sending
one byte from master to slave, you don't need this much complication.
You could do something as simple as this and probably live happily with
it.
GOSUB Get_165 ' returns myByte
checkByte = ~myByte
SEROUT pin, baud, [noparse][[/noparse]myByte, checkByte]
Then on the slave side:
SERIN pin, baud, [noparse][[/noparse]theByte, checkByte]
myCheck = ~theByte
IF (myCheck = checkByte) THEN
' put theByte on P0 - P7
OUTL = theByte
ELSE
' deal with transmission error
END
I hope this helps.
-- Jon Williams
-- Dallas Office
From: Ian Phillips [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=xPVTCmyqZDLJe9VnaOojCxJnWDgy96DmCcHYsDPjDhCsOEPEKM1c38DnL6P3cyWZTEY_g6qtsyOS8Q6JDSM]iphillips@s...[/url
Sent: Wednesday, July 21, 2004 1:48 PM
Subject: RE: [noparse][[/noparse]basicstamps] CRC and the stamp
Thanks again Jon for the info. I have been studying the code you posted
and now a couple of questions. Will this work the same if I just replace
the TstStream data with my byte to be sent? The code you posted would be
just used to decode a sent byte correct? To encode the crc I would have
to alter the Subroutine, I think. I am using a 165 shift register to
read switches and send to another 2sx and if the byte is true, output a
HIGH to a pin. Sorry to drag on about this. I am starting to get the
programming stuff down, but I was never that good at math.
Ian
The application is a bomb bay door type of newspaper dropper.
The unit is on chain motors and they (proverbial) don't want any wires
running to it. Thus the wireless and then error concerns.
I'll try the simpler version but keep the crc for future projects.
Thanks again.
Ian
From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vHosg8AddGYOmbxjuChWy_8HrqCXWq_giNVYTKtrHaEUJrocsG13z_WuEACMfjzobqbkfKgtHSLH6ImfBK3b]jwilliams@p...[/url
Sent: July 21, 2004 3:19 PM
I can't really answer details about the algorithm, I just implemented
subroutine.
it.
checkByte = ~myByte
myCheck = ~theByte
OUTL = theByte
ELSE
END
I hope this helps.
-- Jon Williams
-- Dallas Office
wrote:
> Here's a bit of code I used in a Stamp-to-PC program...
For what it's worth, it appears to me that this is an implementation
of CRC-16.
