(no subject) - toggling all outputs to test a Stamp
--- In basicstamps@yahoogroups.com, Newzed@a... wrote:
> I think this is right just want to check. I want to toggle all 16
I/O ports
> to check a BS2. Will this do it
> outs = 1
> do
> toggle outs
> pause 200
> loop
> Sid
> [noparse][[/noparse]Non-text portions of this message have been removed]
maintenance post to put a searchable subject line on the post.
Dave
I/O ports
> outs = 1
> do
> toggle outs
> pause 200
> loop
> Sid
Dave
Start with
dirs=$ffff ' to set all pins outputs
outs=0 ' that's what it will be anyway
DO
TOGGLE outs
PAUSE 200
LOOP
I use a test board that has RC circuits tied to each pin. The RCTIME
command tests both the output and the input capabilities and also
tests for short circuits between pins.
-- Tracy
>I/O ports
>> outs = 1
>> do
>> toggle outs
>> pause 200
>> loop
>> Sid
>Dave
It seems a good idea to me to check outputs AND inputs using a RCTIME setup.
But how do you check the results?
A debug statement, I would assume. Then you also check if the serial IO is
working properly.
Klaus
Sent: Wednesday, July 21, 2004 1:00 AM
Subject: [noparse][[/noparse]basicstamps] Re: (no subject) - toggling all outputs to test a
Stamp
> Sid,
> Start with
> DO
> TOGGLE outs
> PAUSE 200
> LOOP
> -- Tracy
> >I/O ports
> >> outs = 1
> >> do
> >> toggle outs
> >> pause 200
> >> loop
> >> Sid
> >Dave
> Yahoo! Groups Links
differences in the pin behavior. Here is the exercise program. IT
is more that that because in my systems I also need to test auxio
functionality.
' {$STAMP BS2PE}
' {$PBASIC 2.5}
' testpins.bpe
' http://www.emesystems.com
' tests BASIC Stamp 2pe pins for functionality
' of input and output high and low
' and detects shorted pins
' RC circuit on each pin, 0.01uf & 100kohm
' parallel to Vss
' readings should be pin#, value =~650, value =1
wx VAR Word
wy VAR Word
ix VAR Nib
Allpins:
DEBUG CLS
MAINIO
DO
FOR ix=0 TO 15 ' test MAINIO pins
LOW ix
HIGH ix
RCTIME ix,1,wx ' wx=~650 means HIGH okay, input okay
HIGH ix
LOW ix
RCTIME ix,1,wy ' wx=1 means LOW okay
DEBUG "p",DEC ix,TAB,DEC wx ,REP 32\4,TAB,wy, REP 32\4, CR
NEXT
DEBUG HOME
LOOP
>Hi Tracy,
>working properly.
>Regards,
>Klaus
>From: "Tracy Allen" <tracy@e...>
>Stamp
>> Sid,
>> Start with
>> DO
>> TOGGLE outs
>> PAUSE 200
>> LOOP
>> -- Tracy
>> >I/O ports
>> >> outs = 1
>> >> do
>> >> toggle outs
>> >> pause 200
>> >> loop
>> >> Sid
>> >Dave
>> Yahoo! Groups Links
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
