Translating a BS2 program to a BS1 program
Hello from Gregg C Levine
I am contemplating obtaining a TI Graphing calculator, so as to be
able to explore the principles behind how it can communicate with
things. That being stated, I have downloaded the code that the fellow
who created the site that facilitates having the calculator to talk to
a BS2, and have examined it. I have here BS1s, can the code be
translated to something that the BS1 can execute?
Gregg C Levine hansolofalcon@w...
"The Force will be with you...Always." Obi-Wan Kenobi
"Use the Force, Luke."· Obi-Wan Kenobi
-- Jon Williams
-- Dallas Office
From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=EptQs7gamGNWG4x9NcL3OpDkGu48K35rmBdUZLigA_QTAqSZRsYoIYQwB0Ra5WCnYNuUj_Hw9V3LFrGJ7lvKws8qJq8BEA]hansolofalcon@w...[/url
Sent: Tuesday, July 20, 2004 4:10 PM
Subject: [noparse][[/noparse]basicstamps] Translating a BS2 program to a BS1 program
I am contemplating obtaining a TI Graphing calculator, so as to be able to explore the principles behind how it can communicate with things. That being stated, I have downloaded the code that the fellow who created the site that facilitates having the calculator to talk to a BS2, and have examined it. I have here BS1s, can the code be translated to something that the BS1 can execute?
Jack, yes please do send me the code, and yes I am interested.
Jon, I'll find, and probably post here, the code, and remember to give
credit where credit is do. And thank you for your advice.
> From: goflo@p... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=vt8Y7sf5uQ6XqWV1vmGhcjHgLxq3oSWnUYi_TEuz_1wPcOVuvHqyi0qauieD6c1dTqkYRZ05ARrQ]goflo@p...[/url
> Sent: Tuesday, July 20, 2004 7:09 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Translating a BS2 program to a BS1
program
> I've gotten a TI83 to talk to a BS1. I can probably find
> the code if you're interested.
> IIRC,
> TI protocol is high inactive: High = 0, Low = 1
> TI pulls tip low for bit = 0, ring low for bit = 1
> Rx then pulls inactive line low
> TI then releases active line and waits for Rx to
> release it's line
> regards, Jack
fellow
talk to
IIRC,
release it's line
regards, Jack
And here is the code that I described:
calcstamp.bs2
serdata var byte
again:
'*****this will wait for serial from calculator
serin 15,396,[noparse][[/noparse]serdata]
'***this will send it to the pc debug screen
debug dec serdata, cr
'***this will send the same data plus 1 back to the calculator
serdata=serdata + 1
serout 15,396,[noparse][[/noparse]serdata]
goto again
That's the BS2 program from the page
http://smallrobot.bizland.com/bs2ti.html
And its courtesy Rick of Norland Research. Rick if your available,
please contact me.
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=yik0Zv1yv2PPGQf4YNi-Z9VWwx4rEbuDXAnLuF6Mi5XIb54fupYmHhf2VCAjGXAtB7KOSAKzo6qZMwRqZzFK]jwilliams@p...[/url
> Sent: Tuesday, July 20, 2004 5:34 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Translating a BS2 program to a BS1
program
> Probably -- but it will depend on what BS2 functions are used. If,
for example, the
> connection is serial and above 2400 baud, then no-go. If it's
synchronous serial
> (SHIFTIN/SHIFTOUT) you'll have to write subroutines.
> -- Jon Williams
> -- Dallas Office
> From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SW1HvOJGaM1xu4EhaqRRp4D3G1N7Lj8vEnB1pSYxaxbmPjxk62foXZOWID0yvtkUtr0EsxOQhM9ca55GefF0O6BL5y4k4g]hansolofalcon@w...[/url
able to explore
stated, I have
can the code be
>calcstamp.bs2
>serdata var byte
>again:
>serdata=serdata + 1
>goto again
>please contact me.
Gregg -
Try this modified program for the BS-1
calcstamp.bs1
'{$STAMP BS1}
symbol serdata = b1
again:
serin 15,0,#serdata
debug #serdata, cr
serdata=serdata + 1
serout 15,0,#serdata
goto again
END
The modifications were to add the SYMBOL statement and remove the VAR statement,
reformat the SERIN/SEROUT commands and change the baudmode parameter, change the decimal formatter from DEC to # and add the END statement. Although this is untested, I suspect it may work.
Bruce Bates
' {$STAMP BS1}
' {$PBASIC 1.0}
SYMBOL serData = B2
Main:
SERIN 7, T2400, serData
DEBUG serData
serData = serData + 1
SEROUT 7, T2400, (serData)
GOTO Main
My only concern would be the use of driven SEROUT mode using the same pin as SERIN. I would be inclined to put a 1K resistor in the serial line to prevent any conflicts.
-- Jon Williams
-- Dallas Office
From: Gregg C Levine [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nCEZLy1SBzIDQ1LCRqfWz3g8ZsdfBAY4vjuEwvarkdtzTbG3_x53rirN0y5DlrKQP3fcp0z6iXutL91OJ49PVPKjg_U]hansolofalcon@w...[/url
Sent: Tuesday, July 20, 2004 7:11 PM
Subject: RE: [noparse][[/noparse]basicstamps] Translating a BS2 program to a BS1 program
calcstamp.bs2
serdata var byte
again:
'***this will send the same data plus 1 back to the calculator serdata=serdata + 1 serout 15,396,[noparse][[/noparse]serdata]
goto again
That's the BS2 program from the page http://smallrobot.bizland.com/bs2ti.html
And its courtesy Rick of Norland Research. Rick if your available, please contact me.
> From: Jon Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MMi8cOy1aKleGBQKlFI34WVee3npgsJwNUxsqXYD8JHbA6xSAOTu_vURUsAsD878FfPJOHRGa3bmCJErJg]jwilliams@p...[/url
program
for example, the
synchronous serial
> -- Jon Williams
> -- Dallas Office
able to explore
stated, I have
can the code be
> And here is the code that I described: ... calcstamp.bs2
AFAIK native TI83 I/O does not support 2400 baud serial data,
so the guy must've written such a routine for the 83 - Not much
to stop you from doing the same; There's enough information at
http://www.ticalc.org/ to get you started.
