Sparratic data
I just connected an Analog devices ADXL311 accelerometer to my BS2 through a
LTC1298 ADC, however i've found that i get seemingly random data outputs when
run according to the specifications of both IC's. What could be causing this?
Christian T. Wentz
Christian T. Wentz
writes:
> I have the circuit running off battery supply, and the LTC seems to work
> fine by
> itself - the capacitors are as recommended by Analog Devices, but maybe i'll
> try using capacitors for a different bandwidth and see how that goes.
If your ADC is like my ADC, you should have a .1ufd bypass on each ADC input
pin, and a 1.2K resistor in series with the ADC input. Works wonders for
stability.
Sid
Run off a battery to cancel out power supply affects....
Sent: Tuesday, July 20, 2004 2:20 PM
Subject: [noparse][[/noparse]basicstamps] Sparratic data
a
when
this?
> Thanks,
> Christian T. Wentz
> Yahoo! Groups Links
Do you have the right capacitors on the ADXL?
What happens if you disconnect the ADXL from the LTC?
Does the shiftin/shiftout and CS high/low for the LTC work as it should?
(software).
I would try to get the LTC working properly first. Then afterwards connect
the ADXL.
Succes,
Klaus
Sent: Wednesday, July 21, 2004 12:12 AM
Subject: Re: [noparse][[/noparse]basicstamps] Sparratic data
> Noise?!
> From: "Christian T. Wentz" <cwentz@m...>
through
> a
> when
> this?
> > Thanks,
> > Christian T. Wentz
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
Quoting SB <steve.brady@r...>:
> Noise?!
> a
> when
> this?
> > Thanks,
> > Christian T. Wentz
> > Yahoo! Groups Links
> Yahoo! Groups Links
Christian T. Wentz
BUT, we did run a LONG data line out of p16 and found that I had to add an
RC filter to clean it up enough to be ingested properly.
but narrowing your bandwidth should help.
I don't know about a pull (up/down) resistor in your application.
Is it giving bad readings BETWEEN readings? or is the noise actually in the
data?! Not sure if that makes sense....basically that the Signal to noise
ratio is good enough for the actual data, but when the data is absent the
noise causes false data....
Have you tried disconnecting power to the ADXL (but leaving it connected to
the LTC)? I like working backwords like this....remove power to a device --
problem persists?....then remove data lines (like mini antennas) -- problem
persists? Ground unused inputs -- problem persists? RC filter....cap to
ground....
This takes me to the stamp....I doubt your noise is here...more likely at
the LTC.
You working under a flourescent lamp? Near an electric field? You drying
your hair while working on stamps?? lol
how long is the wire run between the ADXL and your LTC??
Sent: Tuesday, July 20, 2004 7:39 PM
fine by
i'll
> > Noise?!
through
> > a
outputs
> > when
causing
> > this?
> > > Thanks,
> > > Christian T. Wentz
and
> > > Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Christian T. Wentz
> Yahoo! Groups Links
