storing data into an array
Hi stampers,
i want to create a sort of array. It's hard to explain my intentions
but I try to do this by an example:
input=1
1=value1
2=value2
3=value3
input=2
1=value4
2=value5
3=value6
So when my input chances by value, the program calls a sort of colum
from the array and gives 1,2 and 3 the values:
array
input | 1 | 2 | 3 |
1 |value1 |value2 |value3 |
2 |value4 |value5 |value6 |
3 |value7 |value8 |value9 |
... |value..|value..|value..|
I probiately could do it with branch but I must also be able to
change the contence of the "value.." with pushbuttons so a good
acces of changing the values is a must.
Could anybody help me or give me a link?
kindly regards,
Tim
input=1
1=value1
2=value2
3=value3
input=2
1=value4
2=value5
3=value6
array
input | 1 | 2 | 3 |
kindly regards,
Tim
The following may get you going in a useful direction:
LOOKUP INPUTX - 1,[noparse][[/noparse]value(1), value(4), value(7), ...],result1
LOOKUP INPUTX - 1,[noparse][[/noparse]value(2), value(5), value(8), ...],result2
LOOKUP INPUTX - 1,[noparse][[/noparse]value(3), value(6), value(9), ...],result3
This will assign one of several values to result1, result2 and
result3 depending on the value of INPUTX (e.g., when INPUTX = 1,
result1 will be value(1), result2 will be value(2) and result3 will
be value(3). The contents of the value array can be modified in
other parts of your program.
Alternatively, you could use the value of INPUTX and a value
associated with each desired result to calculate a direct index into
the array (e.g, result2 = value(INPUTX * 3 - 1).
Steve
On 18 Jul 04 at 15:32, ikenniemandanders wrote:
> Hi stampers,
> input=1
> 1=value1
> 2=value2
> 3=value3
> input=2
> 1=value4
> 2=value5
> 3=value6
> array
> input | 1 | 2 | 3 |
