BS2 Accuracy
If I build a tach circuit for a BS2 how is the best way to determine the
accuracy.
My idea was to use a standard industrial magnetic pickup, fed to a NPN
transistor, then to the stamp.
The stamp would time the pulses, then output to a 10 bit dac indicating RPM
in voltage of 0-5 vdc.
My flywheel would be rotating up to 1800 rpm, and I would count flywheel
teeth anywhere from 183 to 208 depending on the engine.
I figured since I'm using a 10 bit dac, I would make the design range good
for 2048 RPM so each step of the dac would be equiv. to 1 rpm.
For example, say I have an engine running @ 1500 rpm and it has 183 flywheel
teeth. = 274500 / 60 = 4575 hz
The Dac would output 3.66 volts or 1500 steps.
How is the best way to determine the accuracy of the measurement?
[noparse][[/noparse]Scanned by AwesomeNet Anti-Virus]
accuracy.
Sent: Sunday, July 18, 2004 8:46 AM
Subject: [noparse][[/noparse]basicstamps] BS2 Accuracy
> accuracy.
RPM
flywheel
> Yahoo! Groups Links
> [noparse][[/noparse]...] How is the best way to determine the accuracy of the
> measurement?
Generally, accuracy is determined by comparing a result against a
another result from a device of known accuracy.
When I built a Stamp-based controller for my diesel genset, I used a
magnetic pickup mounted near the flywheel teeth as you describe. The
output from the pickup was clipped and fed to a transistor to sharpen
the waveform and then fed to the BS2. In my case, I displayed the
RPM value on an LCD instead of generating a proportional analog
voltage. I compared the displayed result to the value from a
frequency counter.
You can get more information on my project, including schematics and
source code at:
http://www.kinzers.com/don/GenSet
I recently made a tachometer for a friend's boat. It runs in the same sort
of range that you are looking at. I used a magnet on the flywheel and a hall
sensor with a built in Schmitt trigger.To verify the accuracy, I used an
Optascope. It agrees perfectly with the Stamp.
Jonathan
www.madlabs.info
Sent: Sunday, July 18, 2004 6:46 AM
> accuracy.
RPM
flywheel
> Yahoo! Groups Links
output with a calibrated instrument.
-- Jon Williams
-- Dallas Office
From: Richard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L0uPyszTqIwoTsqC6oW2tdmPpdjVyTyNUC5LpvcofKDWmCjGX38yahXemjFPBYNDbCZ7VNfyaQIyJ2GFvQl_]rwskinner@a...[/url
Sent: Sunday, July 18, 2004 8:47 AM
accuracy.
transistor, then to the stamp. The stamp would time the pulses, then
output to a 10 bit dac indicating RPM in voltage of 0-5 vdc.
flywheel teeth anywhere from 183 to 208 depending on the engine.
good for 2048 RPM so each step of the dac would be equiv. to 1 rpm.
flywheel teeth. = 274500 / 60 = 4575 hz The Dac would output 3.66 volts
or 1500 steps.
With the 10 bit DAC, that is 1024 steps, so with 2048rpm full scale,
that is 2rpm per bit (not 1rpm!). Let's say you have a reading of
1000. If the accuracy of the DAC is 1 bit, then your rpm could be
anywhere from 998 to 1002. There may be other errors (linearity,
offset, monotonicity) in the DAC that you need to consider. If you
have an accurate voltmeter, you can use that to check the calibration
of the DAC and to make adjustments in software if need be.
The accuracy of the stamp resonator affects the accuracy of the COUNT
command. These resonators are typically very good, but the
specification is not as tight as a crystal. +/- 0.5 percent initial
accuracy and +/- 0.3 percent change over a -20 to +80 temperature
range. So just to take 0.5% of 1000 rpm, that is +/- 5 rpm. You can
measure the accuracy of your ceramic resonator by feeding an accurate
frequency source into a stamp pin, and COUNT for a long enough
period. That way you can calibrate the COUNT command for that
particular Stamp.
Once you calibrate both the DAC and the COUNT command, those are the
error sources in this system, assuming the magnetic pickup is working
as it should.
-- Tracy
>accuracy.
asleep I guess.
Sorry, I asked my question incorrectly. I know how to compare readings
between instruments, but I was curious to how accurate the stamp would be
using the count command with my frequency range.
The stamp would be pretty much dedicated to RPM and Voltage output. I'd
like to get 2 samples per second and hold it within about 5 rpm accuracy .
I could use offsets if needed since we "mainly" care about the 700-1500 RPM
Range.
Sent: Monday, July 19, 2004 10:14 AM
Subject: Re: [noparse][[/noparse]basicstamps] BS2 Accuracy
> You could do a worst case analysis.
> particular Stamp.
> as it should.
> -- Tracy
> >accuracy.
RPM
good
flywheel
> Yahoo! Groups Links
