Programming a PIC microcontroller
Is it possible to use the Basic Stamp Editor/Development System
Version 2.1 Beta 1, to program a PIC microcontroller such as the
PIC16F84?
PIC16F84?
> PIC16F84?
NO, plain an simple.
The methods of writing the program to the hardware are two totally
incompatable methods.
Dave
-- Jon Williams
-- Dallas Office
From: lindsey_chew [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=x2fJxXcd2dmEHcNej2xJtMkxg1ByQ7yJDykKyN-yJH6HHjZqZ1whui3dpSGY6L_wL3oUGi0uLZac]lchew@l...[/url
Sent: Friday, July 16, 2004 7:28 AM
Subject: [noparse][[/noparse]basicstamps] Programming a PIC microcontroller
PIC16F84?
than that.
You see, the way the Stamp platforms work is to have
an 'interpreter' program coded into a non-programmable
PIC chip. This 'interpreter' also includes a 'loader'
program -- which the IDE uses to load a 'tokenized'
version of your program into an on-module EEPROM.
Then, when you 'run' your program, the tokenized
version is read from EEPROM. The tokens cause
PBasic run-time routines to be executed on the
PIC.
In addition, the 'module' has an on-module
clock resonator, a on-module power regulator,
and on-module RS-232 receiver/driver circuit
(doing what a MAX232 does). All these circuits
are debugged, and the module will run with
voltage from 6 volts to 12 volts DC.
So you see, a Stamp gives you much more capability
than a plain 'PIC' chip would. It takes much
less hardware to program it, also. This should
also answer the question why you can't use the
Stamp IDE to program a 'plain' 16F84 -- there is
no 'loader' in the 16F84 to start, and you don't
have the code to the interpreter, which is partly
what Parallax is selling you when you buy a Stamp.
The Stamp IDE really-really expects to have a
Stamp on the other end of the cable -- not a plain
PIC.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> No.
> -- Jon Williams
> -- Dallas Office
> From: lindsey_chew [noparse][[/noparse]mailto:lchew@l...]
> PIC16F84?
>PIC16F84?
That's a loaded question!
On one level - yes you could. That is: you could add the tiny amount of
extra hardware needed to switch Vpp & Vdd and write a PBasic program to
read a hex file from your PC and burn that code into a PIC. In other
words, you could use a Stamp as the brains behind a PIC programmer.
However, I suspect that you are asking if you can use the Basic Stamp
development system to create code ready to be burned into a PIC. The two
possible answers are: NO and maybe.
No - the Basic Stamp development system does not generate code directly
compatible with a PIC.
Maybe - because that source code can MOST LIKELY be used by one of the
several PIC Basic compilers available. Those compilers do generate code
that can be burned into a PIC.
Hope this helps.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 20 years of Engineering Innovation (1984 - 2004)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
> >PIC16F84?
amount of
program to
other
Stamp
The two
directly
the
code
> Hope this helps.
> dwayne
um... it might need a little tweeaking to get it to run properly, so
you probably would need one of the PIC basic compliers that are
available. PicBasicPro goes for around $250.00 and if you are in the
States, the exchange rate for Pronton+ is 1.87. Proton+ is going for
150 Pound so, times 1.87 makes that $280.00 USD.
So, you are correct that you can port PBasic to a PIC, but that
requires something of a full wallet.
Many of us have done the math to find the break even point and the
OEM version of the Stamp raises the bar even higher.
But, if you are hoping that PBasic can be used instead of one of
those compliers... alas, your hopes are dashed on the rocks.
Dave
a 16f84 compiler & some other stuff. Check out http://www.melabs.com.
> PIC16F84?
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Sean T. Lamont, Director Of Engineering
Innovative Communications Technologies, Inc. http://www.ict.net
email: lamont@a... / sean@i...
"Do not fear mistakes, There Are None" - Miles Davis
