Math coprocessors
Hello,
I am making a design and to get the accuracy I want from the
sensor I am using I have to crunch some heavy numbers like: -2.8*10^-
6 which is -.0000028 and -.00000002 and was wondering if there was
any simple way to do it using the BS2? The problem is the 16 bit
math and I was looking into getting a 32 bit math co processor and
was wondering if you guys had any to suggest to me?
thanks for your help,
mark
mark
alw@a... writes:
It is almost like having an
HP-style calculator on a serial port.
Al,
When you say HP-style, do you mean RPN notation?
Ken
the PAK-II handles things like trig and logs. The PAK-IX is similar to a
PAK-II but adds A/D. The PAK-XII has a simpler (but in some cases less
efficient) RS232 interface and includes A/D. It is almost like having an
All of these are 32-bit coprocessors. Any 32-bit floating point system
should handle 24 bits of significant digits. The remaining bits are for the
exponent. We have a wealth of sample code, much of it for the Stamp.
Links:
http://www.awce.com/pak1.htm - PAK 1 & 2
http://www.awce.com/pak9.htm - PAK 9
http://www.awce.com/pak12.htm - PAK 12
http://www.awce.com/doclib.htm - Examples
The PAK-XII is fairly new, but the other devices have long track records and
are successfully deployed in a wide range of equipment.
Al Williams
AWC
From: uebermenchens [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pomo3iwfq_oC-vLwpT-NVmKjsX2iSsP7mgO2WudsaBMel8FKtY09G4BegdfnUXISHuvATe12JqQMAU5CTqlR]uebermenchens@a...[/url
Sent: Thursday, July 15, 2004 8:57 PM
Subject: [noparse][[/noparse]basicstamps] Math coprocessors
Hello,
sensor I am using I have to crunch some heavy numbers like: -2.8*10^- 6
mark
Yahoo! Groups Links
1 4 / =
Prints out something like 0.25 (the manual has all the exact formatting).
Al Williams
AWC
From: smartdim@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=s-okO8NkKrBquZb352vvkRrdig00V1xES4qfVJcAR-1EteB3OcRaIs_hhx2EnEEM2mnRcoXKwwp2]smartdim@a...[/url
Sent: Friday, July 16, 2004 9:07 AM
Subject: Re: [noparse][[/noparse]basicstamps] Math coprocessors
In a message dated 7/16/2004 5:51:07 AM Pacific Standard Time,
alw@a... writes:
Al,
Ken
Yahoo! Groups Links
