Pulse-Per-Second PIN on GPS module
Hello all,
I am new to electronics so pardon this elementary question.
I am trying to interface my Basic Stamp to a GPS module (LassenSQ)
From the datasheet, it has a total of 8 pins, 3 reserved,
TXD,RXD,GND,Vcc,battery backup and a Pulse per second pin.
I am ok with all but the last one. Pulse per second confuses me a bit.
I assume that I will use SHIFTIN to read data from this module...
but I am not sure how to connect it.
Will I be writing to PPS pin or reading from it?
Could I use SERIN?
Could you please direct me to some sort of a tutorial/example on this
topic?
Could I use SERIN?
topic?
output a short pulse every second once it aquires the a lock on the
satellites. You won't need the PPS signal for communication between
the GPS and the stamp.
--- In basicstamps@yahoogroups.com, "mirza_sejto" <mirza_sejto@y...>
wrote:
> Hello all,
> Could I use SERIN?
> topic?
