Large BS2P-40 project
i'm making a very large problem. I'm having a large menu by LCD
display. My program is too large to download it to the stamp. To
give an example of my pin connection:
0 = Not used |
1 = Enable |
2 = R/W |
3 = RS | LCD display (going to use an 4x20 display)
4 = DB4 |
5 = DB5 |
6 = DB6 |
7 = DB7 |
8 = CS |
9 = CLK | 12bit ADC (ltc1298)
10 = D I/O |
11 =
12 =
13 =
14 =
15 =
AUX0 = Button 1 |
AUX1 = Button 2 |
AUX2 = Button 3 |
AUX3 = Button 4 | Push buttons
AUX4 = Arrow up |
AUX5 = Arrow down |
AUX6 = Arrow left |
AUX7 = Arrow right |
AUX8 = Low pressure |
AUX9 = High pressure |
AUX10 = Manometer LP |
AUX11 = Manometer HP | outputs
AUX12 = Stikstof |
AUX13 = Freon |
AUX14 = Vacuum |
AUX15 = Air |
To give an example of how i'm creating my menu:
menu:
LCDOUT 1,cleardisplay, [noparse][[/noparse]"1) Volledige test"]
LCDOUT 1,movecrsr+64,[noparse][[/noparse]"2) Vacuumtest"]
LCDOUT 1,movecrsr+148,[noparse][[/noparse]"3) Druktest"]
LCDOUT 1,movecrsr+212,[noparse][[/noparse]"4) Instellingen"]
PAUSE 1000
a=0
menu_2:
IF in21=0 THEN volledige_test
IF in22=0 THEN vacuum_test
IF in23=0 THEN druk_test
IF in24=0 THEN instellen
GOTO menu_2
Volledige_test:
LCDOUT 1,cleardisplay, [noparse][[/noparse]"1) Daikin"]
LCDOUT 1,movecrsr+64,[noparse][[/noparse]"2) Mitsubishi"]
LCDOUT 1,movecrsr+148,[noparse][[/noparse]"3) Terug naar menu"]
PAUSE 1000
a=1
volledige_test_2:
IF in21=0 THEN vol_daikin
IF in22=0 THEN vol_mitsubishi
IF in23=0 THEN menu
GOTO volledige_test_2
' vanaf hier daikin keuze
vol_daikin:
GOSUB type_keuze
vol_daikin_2:
IF in21=0 THEN type_a_dai
IF in22=0 THEN type_b_dai
IF in23=0 THEN type_c_dai
IF in24=0 THEN volledige_test
GOTO vol_daikin_2
' vanaf hier mitsubishi keuze
vol_mitsubishi:
GOSUB type_keuze
vol_mitsubishi_2:
IF in21=0 THEN type_a_mit
IF in22=0 THEN type_b_mit
IF in23=0 THEN type_c_mit
GOTO vol_mitsubishi_2
type_a_dai:
GOSUB start_stop
type_a_dai_2:
IF in21=0 THEN start_typ_a_dai
IF in22=0 THEN algemene_stop
IF in23=0 THEN vol_daikin
GOTO type_a_dai_2
type_b_dai:
GOSUB start_stop
type_b_dai_2:
IF in21=0 THEN start_typ_b_dai
GOTO type_b_dai_2
type_c_dai:
GOSUB start_stop
type_c_dai_2:
IF in21=0 THEN start_typ_c_dai
GOTO type_c_dai_2
type_a_mit:
gosub start_stop
type_a_mit_2:
if in21=0 then start_typ_a_mit
if in22=0 then algemene_stop
if in23=0 then vol_mitsubishi
goto type_a_mit_2
type_b_mit:
gosub start_stop
type_b_mit_2:
if in21=0 then start_typ_b_mit
goto type_b_mit_2
type_c_mit:
gosub start_stop
type_c_mit_2:
if in21=0 then start_typ_c_mit
goto type_c_mit_2
I believe this is the easist way to create an LCD menu. This is only
one tiny part of my menu so U might notice that this will take a
huge amount of memory. I also must be able to write data (al kinds
of variables) to an eeprom memory and recall it when i start my
stamp. Is my method of creating a menu the shortest way or could I
do bether. I'm using so many GOSUB's as I can. Is there a way to
have a lot more memory wich I could maintain my way of creating the
program (not with a lot of writing sentences to write text to an
smartcard of an eeprom memory)? This are a few hard questions to
answer but I hope somebody could answer me on one or more of these
questions.
Kindly regards,
Tim (an desperate student @ belgium)
0 = Not used |
1 = Enable |
2 = R/W |
4 = DB4 |
5 = DB5 |
6 = DB6 |
7 = DB7 |
8 = CS |
10 = D I/O |
11 =
12 =
13 =
14 =
15 =
AUX0 = Button 1 |
AUX1 = Button 2 |
AUX2 = Button 3 |
AUX4 = Arrow up |
AUX5 = Arrow down |
AUX6 = Arrow left |
AUX12 = Stikstof |
AUX13 = Freon |
AUX14 = Vacuum |
AUX15 = Air |
menu:
PAUSE 1000
a=0
menu_2:
GOTO menu_2
Volledige_test:
PAUSE 1000
a=1
volledige_test_2:
IF in23=0 THEN menu
vol_daikin:
GOSUB type_keuze
vol_daikin_2:
GOTO vol_daikin_2
vol_mitsubishi:
GOSUB type_keuze
vol_mitsubishi_2:
type_a_dai:
GOSUB start_stop
type_a_dai_2:
GOTO type_a_dai_2
type_b_dai:
GOSUB start_stop
type_b_dai_2:
GOTO type_b_dai_2
type_c_dai:
GOSUB start_stop
type_c_dai_2:
GOTO type_c_dai_2
type_a_mit:
gosub start_stop
type_a_mit_2:
goto type_a_mit_2
type_b_mit:
gosub start_stop
type_b_mit_2:
goto type_b_mit_2
type_c_mit:
gosub start_stop
type_c_mit_2:
goto type_c_mit_2
questions.
Kindly regards,
you really don't need to put each state of the menu into the program itself. instead, i
would do something like this:
put each state of the menu into eeprom, and then link them by also including the address
in the eeprom of where each menu "button" leads to.
then your program can just read the first menu from the eeprom, and wait for user input.
when that comes, just jump to the next address in memory that you need.
so in the eeprom you would store something like this:
menu choice 1, address1
menu choice 2, address2
menu choice 3, address3
granted, everything would need to be a fixed length so that you know where you can find
the information.
i don't think i did a very good job explaining this, but i don't know that much about
eeprom commands myself, and am sure that somebody else can do a better job.
--- In basicstamps@yahoogroups.com, "ikenniemandanders" <tld-nv@s...> wrote:
> Hi,
> 0 = Not used |
> 1 = Enable |
> 2 = R/W |
> 4 = DB4 |
> 5 = DB5 |
> 6 = DB6 |
> 7 = DB7 |
> 8 = CS |
> 10 = D I/O |
> 11 =
> 12 =
> 13 =
> 14 =
> 15 =
> AUX0 = Button 1 |
> AUX1 = Button 2 |
> AUX2 = Button 3 |
> AUX4 = Arrow up |
> AUX5 = Arrow down |
> AUX6 = Arrow left |
> AUX12 = Stikstof |
> AUX13 = Freon |
> AUX14 = Vacuum |
> AUX15 = Air |
> menu:
> PAUSE 1000
> a=0
> menu_2:
> GOTO menu_2
> Volledige_test:
> PAUSE 1000
> a=1
> volledige_test_2:
> IF in23=0 THEN menu
> vol_daikin:
> GOSUB type_keuze
> vol_daikin_2:
> GOTO vol_daikin_2
> vol_mitsubishi:
> GOSUB type_keuze
> vol_mitsubishi_2:
> type_a_dai:
> GOSUB start_stop
> type_a_dai_2:
> GOTO type_a_dai_2
> type_b_dai:
> GOSUB start_stop
> type_b_dai_2:
> GOTO type_b_dai_2
> type_c_dai:
> GOSUB start_stop
> type_c_dai_2:
> GOTO type_c_dai_2
> type_a_mit:
> gosub start_stop
> type_a_mit_2:
> goto type_a_mit_2
> type_b_mit:
> gosub start_stop
> type_b_mit_2:
> goto type_b_mit_2
> type_c_mit:
> gosub start_stop
> type_c_mit_2:
> goto type_c_mit_2
> questions.
> Kindly regards,
text it is more efficient to store it in DATA statements, and then
have one routine that you call with a pointer to the screen of
information that you want to display, for example:
screen1: DATA [noparse][[/noparse]"1) Volledige test"],CR
DATA [noparse][[/noparse]"2) Vacuumtest"],CR
DATA,,[noparse][[/noparse]"3) Druktest"],CR
DATA [noparse][[/noparse]"4) Instellingen"],0 ' terminating null
' and to call that...
pointer=screen1
GOSUB show_Screen
Then you need a little show_Screen routine that reads the data one
character at a time and sends the commands and the 4 lines to the
screen. You call that same routine to display any screen content
based on the pointer. It has to start by clearing the screen, and it
has to trap the CR and move to the beginning of the next screen line,
and finish when it detects the null. If you have many screens of
data, this will take lots less memory than storing the data in
individual LCDOUT commands.
Things like this...
I wonder what is in21..in24? The inX only goes from 0 to 15 and you
need to use AUXIO and MAINIO to switch between sets of 16.
If you can have those buttons on one nibble, it could be coded with a
BRANCH, something like this...
waiting:
BRANCH NCD ~inB, [noparse][[/noparse]waiting,volledige_test, vacuum_test, druk_test, instellen]
The NCD~inB uses one of the math operators on the 4 bits of port
(nibble
%1111 = 0
%1110 = 1
%1101 = 2
%1011 = 3
%0111 = 4
selecting the branch option that loops until some button is pressed
and then jumps to the selected routine.
