Using a FIFO register to stable my incoming ADC values
Hi stampworkers,
I'm reading in an 4-20mA pressure sensor with an LTC1298. This works
very good but my values keep changing a little bit and I want to
make them as stable as I can so I thought an FIFO register software
loop would do the trick. My idea is to create an 10 adress FIFO
register, to make the sum of the 10 values en the devide it by 10 so
I get an average value of the reading wich will be stable
(hopefully). I searched a lot in nuts & volts and in my printed
manuals but didn't found a proper article about creating such
register. Do I need some kind of IC to make my idea work or could i
do this by inserting some program text? Could anyone help me with me
very enoying problem?
Greetings,
Tim (happy but not satisfied)
Greetings,
T10 you want to average samples T1 to T10 and at T11 you want T2 to T11, is
that right?
In theory, this is easy enough, but there are some caveats. The easy thing
to do is create an array of 10 items and keep a "pointer" to the current
entry. So putting an entry in this list would be something like:
List(current)=value
current=current+1
if current>9 then current=0
But there are a few problems. First, the LTC1298 is 12 bit. So you'd need 10
words or 20 bytes for the list, and an extra nibble for the pointer. That
leaves less than 6 bytes for other things. In addition, consider this
averaging code:
V=0
For I=0 to 9
V=V+List(I)
Next
V=V/10
Of course, this uses more variables. But worse still is that at the worst
case, List(I) could be $FFF (say 4000 for round numbers) and you are
multiplying by 10 which would be 40000. That's less than 65535 so you should
be OK there. But if the values were possibly larger, or you tried to
increase the number of samples (doubtful with limited memory) you'd overflow
the Stamp.
Answers? You could use a BS2/P's scratch pad memory for the list. You could
reduce the number of samples in the average. You could go with a "spot"
average:
V=0
For I=1 to 10
V=V+Input_Value_From_LTC
Next
V=V/10
Next time you just read 10 more values.
Another approach is to oversample. If you decide you only need, say, 8 bits
of resolution, you can simply round the 12 bits to 8 by shifting and taking
the last shifted bit into account for rounding:
V8=v12>>4 + v12.bit3
You could probably use a PAK-II to do the average, by storing the list in
the PAKs memory. This would also give you a floating point number and a way
to convert to engineering units. Or use a PAK-IX or PAK-XII to do the A/D.
These are only 10 bit, but averaging adds bits in the presence of random
noise. Both chips do floating point and can average samples right out of the
box (spot average, though -- you'd have to do your own rolling averages).
See http://www.awce.com/pak12.htm or http://www.awce.com/pak9.htm (or
http://www.awce.com/pak1.htm if you don't want the A/D onboard).
A better approach might be to identify the noise in your system and reduce
it first. Keep in mind that 12 bits at 5V is about one and quarter
millivolts per step. That's not a lot of voltage. Decoupling, ground design,
etc. get very important when you are trying to measure things down to the
millivolt. If you put a scope on AC coupling and turn the vertical gain up
high, you'll see that most DC sources have a few millivolts of up and down
riding on them -- many quite a few millivolts!
Hope that helps.
Al Williams
AWC
* 8 Channels of PWM from your Stamp
http://www.awce.com/pak5.htm
From: ikenniemandanders [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LNRiw3SEt3T0t6XOR4C7C2A3QMib41gSkp31CoKN1fU-zOrHmFXxMJhMuUYh7oZ_21VFA70KUYORHg]tld-nv@s...[/url
Sent: Wednesday, July 14, 2004 9:34 AM
Subject: [noparse][[/noparse]basicstamps] Using a FIFO register to stable my incoming ADC
values
Hi stampworkers,
Greetings,
Yahoo! Groups Links
wrote:
> Hi stampworkers,
works
so
me
> Greetings,
Hi Tim,
If you use a spreadsheet, try to enter a few hundred points of raw
data to experiment with.
I use a 10 point filter that adds a new reading, averages the
readings and then deletes the average.
The can take 150 readings to resolve a full scale shift, but one
question is how fast you take readings.
One problem is adding up large values and memory use.
but I read one point, add it to my old running total, then divide by
10 to get the average. that average is then sent to the porgram for
use or readout.
that avearage is also subtracted from the running total to keep the
running total something close to the value of the last 10 points.
I don't have a 2,000 point data stream to play with on my
spreadsheet, but I'll put it on my to-do list (around page 75 ?)
The way you are talking about a FIFO buffer I did the long way.
X10=X9
X9=X8
X8=X7
X7=X6
X6=X5
X5=X4
X4=X3
X3=X2
X2=X1
X1=new adc input
The old value of X10 would be lost and replaced with X9 and so on.
X1 would get the new data.
But, as anyone will tell you, averaging your data in some hardware
filter (butteworth, or op-amp or RC or something) will go a long way
to get better input readings.
Dave
' from http://owlogic.com/BS2math5.htm#Smoothing
X var word ' current noisy value, filter input 0<=X<4096
Y var word ' accumulator
Z var word ' smoothed filter output
inititalize:
gosub getX ' get current value, not shown, X<4096
Y=X*16 'initialize, note multiplication *16
main:
Y = Y ** 61441 + X ' smoothing function
Z = Y/16
debug dec X, tab,dec Z, CR ' show values
goto main
Basically each new sample contributes a weight of 1/16 to the pool of
past samples. The article shows other weightings too.
It is possible to implement the kind of windowed or boxcar average
that you describe. However, as Al pointed out, you would need more
RAM memory, available in the scratchpad memory of the multibank
Stamps, to implement that.
-- Tracy
>Hi stampworkers,
>Greetings,
use a power of 2, so I use a rolling average of n=16. With Al's
example, 16 * 4000 = 64000, so this is still within a 2-byte boundary (<
65535). Code is also simplified if you add the first 16 values and
store it in a 2-byte buffer, and then recursivly add the 17th, subtract
the first, divide by 16, send the result to a PC, and continue this
logic forever. The main message is that you never have to actually
store all 16 values, just the cumulative buffer.
Remember that a rolling average is a low-pass filter, with filter cutoff
determined by the sampling rate and n.
Dennis
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=t_WPY41A8OMG1GnOt71tHHwDmr9p-Tsys1mETAPfmzBT1pcY-mKF_-fTuUwhTAhxhpCKCzfRn8Jb]alw@a...[/url
Sent: Wednesday, July 14, 2004 8:21 AM
Subject: RE: [noparse][[/noparse]basicstamps] Using a FIFO register to stable my incoming
ADC values
If I understand your question, you really want a rolling average. That
is at T10 you want to average samples T1 to T10 and at T11 you want T2
to T11, is that right?
thing to do is create an array of 10 items and keep a "pointer" to the
current entry. So putting an entry in this list would be something like:
List(current)=value
current=current+1
need 10 words or 20 bytes for the list, and an extra nibble for the
pointer. That leaves less than 6 bytes for other things. In addition,
consider this averaging code:
V=0
For I=0 to 9
V=V+List(I)
Next
V=V/10
worst case, List(I) could be $FFF (say 4000 for round numbers) and you
are multiplying by 10 which would be 40000. That's less than 65535 so
you should be OK there. But if the values were possibly larger, or you
tried to increase the number of samples (doubtful with limited memory)
you'd overflow the Stamp.
could reduce the number of samples in the average. You could go with a
"spot"
average:
V=0
For I=1 to 10
Next
V=V/10
bits of resolution, you can simply round the 12 bits to 8 by shifting
and taking the last shifted bit into account for rounding:
in the PAKs memory. This would also give you a floating point number and
a way to convert to engineering units. Or use a PAK-IX or PAK-XII to do
the A/D. These are only 10 bit, but averaging adds bits in the presence
of random noise. Both chips do floating point and can average samples
right out of the box (spot average, though -- you'd have to do your own
rolling averages). See http://www.awce.com/pak12.htm or
http://www.awce.com/pak9.htm (or http://www.awce.com/pak1.htm if you
reduce it first. Keep in mind that 12 bits at 5V is about one and
quarter millivolts per step. That's not a lot of voltage. Decoupling,
ground design, etc. get very important when you are trying to measure
things down to the millivolt. If you put a scope on AC coupling and turn
the vertical gain up high, you'll see that most DC sources have a few
millivolts of up and down riding on them -- many quite a few millivolts!
Hope that helps.
Al Williams
AWC
* 8 Channels of PWM from your Stamp http://www.awce.com/pak5.htm
From: ikenniemandanders [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DySVav7KPI9Wt_m0cHfnHMHTLEsoUWV0geuHbb9zEtQdjNP7yRqZM2oI64pRmR90CXGP3OH_r_RzkXg]tld-nv@s...[/url
values
Hi stampworkers,
Greetings,
Yahoo! Groups Links
Yahoo! Groups Links
S(i+1)=S(i)+V(i+1)-V(i-16) { or whatever }
You still have to store V(0) to V(15) so that you can supply the V(i-16)
part. Or did I misunderstand you?
Al Williams
AWC
* NEW: I2C PC Interface
http://www.awce.com/gp7.htm
From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=e4Ky0kPY_Uy_1NItdHZQWbmXvcEsjRz8Q-IsNk-i8wtom0nGRORYtqsdQvcWeYHmrxM4GYXN-5xTG8Im]doleary@e...[/url
Sent: Thursday, July 15, 2004 12:57 PM
Subject: RE: [noparse][[/noparse]basicstamps] Using a FIFO register to stable my incoming ADC
values
I use this technique with a 12-bit ADC. Division is simplified if you use a
power of 2, so I use a rolling average of n=16. With Al's example, 16 *
4000 = 64000, so this is still within a 2-byte boundary (< 65535). Code is
also simplified if you add the first 16 values and store it in a 2-byte
buffer, and then recursivly add the 17th, subtract the first, divide by 16,
send the result to a PC, and continue this logic forever. The main message
is that you never have to actually store all 16 values, just the cumulative
buffer.
Dennis
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=qe7hKIJvjItjjy-4WpCmzTNHHt9seRTJbbZy37fs5RNvVCJfJPBy51ANbKgd5ezyx5Ylt0lt4HEoJ9g]alw@a...[/url
values
If I understand your question, you really want a rolling average. That is at
that right?
List(current)=value
current=current+1
averaging code:
V=0
For I=0 to 9
V=V+List(I)
Next
V=V/10
the Stamp.
average:
V=0
For I=1 to 10
Next
V=V/10
Hope that helps.
Al Williams
AWC
From: ikenniemandanders [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=N4Qp2UJwTkbsMUjQtw-CtR_yMLFBZjDoOMbbcDHCIBjGAULG8FqUwMJb1UA5Ur4FW00ZmeNv]tld-nv@s...[/url
values
Hi stampworkers,
Greetings,
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
note that dividing by 16 is done by right shifting bits 4 places.
Dennis
WSR, Inc.
www.4wsr.com
From: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=SFFQ-j-ndEGVQ7oKGQA0bmIOgxFQ16LfzpFYOuvKZpytbwMw9aosq1ma0sJivZ2tmyCj_dukJyN2ow]alw@a...[/url
Sent: Thursday, July 15, 2004 11:03 AM
ADC values
Agreed, this is computationally simpler, but to compute:
Al Williams
AWC
From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1D06w-Z_t8XQ0nxkYrHeOOo6fG_OPkR4ThJvHF6CTKFThyLtffRvncAu5S6yTbaL-dnukL5qfPmS-ZV9xPuh]doleary@e...[/url
ADC values
Dennis
ADC values
List(current)=value
current=current+1
V=0
For I=0 to 9
V=V+List(I)
Next
V=V/10
"spot"
average:
V=0
For I=1 to 10
Next
V=V/10
Hope that helps.
Al Williams
AWC
From: ikenniemandanders [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=TP4qp1PUSp6-iAwXKQqLzXpCWy6IAWKQYVwZhg727eOetvi4KJ9lDC9w2h_AXeyBOuXfzDvNig_uzNg]tld-nv@s...[/url
values
Hi stampworkers,
Greetings,
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
Yahoo! Groups Links
