time between pulses
In a message dated 7/12/2004 7:41:25 PM Eastern Daylight Time,
msfwebdude@h... writes:
> With this information I can create a signature of the button on the
> remote and use that button to activate a servo.
If you write pulsein 1, length, you measure the duration of a high pulse.
If you write pulsin 0, length it gives you the duration of the low pulse.
Take a look at this command in the online Help section of the Basic Editor.
Sid
Sid
button on the remmote.
I need to get the length of the pulses and am kinda doing that with
the PULSIN command
the square wave produced by the filtering and other circuits in the
ir module sorta looks like this _
__---_--_
the lengh of the pulse and the length of of time between the pulses
need to be calculated
So far I am able to get the length of the high pulses (see my source
code below)
### I still need to find the time between the high pulses. ###
Thanks for any help.
Mike Firoved
'{$STAMP BS2}
'{$PBASIC 2.5}
'***** PIN ASSIGNMENTS ******
IrModuleInput PIN 0
ServoOutput PIN 1
'*** VARIABLE ASSIGNMENTS ***
xa VAR Word
xb VAR Word
xc VAR Word
xd VAR Word
xe VAR Word
xf VAR Word
start:
PAUSE 1
PULSIN IrModuleInput, 1, xa
IF xa=0 THEN GOTO start
PULSIN IrModuleInput, 1, xb
PULSIN IrModuleInput, 1, xc
PULSIN IrModuleInput, 1, xd
PULSIN IrModuleInput, 1, xe
PULSIN IrModuleInput, 1, xf
DEBUG DEC xa
DEBUG DEC xb
DEBUG DEC xc
DEBUG DEC xd
DEBUG DEC xe
DEBUG DEC xf
GOTO start
things are in a certain state. You lose the
amount of time it takes the BS2 to interpret
the RCTime command, of course.
the
pulse.
pulse.
Editor.
> Sid
