PSC data conversion
Maybe someone out there can help with this one.
I have a BS2 driving a PSC. I want to be able to send commands to
the bs2 in degrees and convert that value to a number that the PSC
can use.
Since every channel travels 180 degrees and through calibration, we
can determine the PSC value for the extreme limits (0-180 degrees)
It should be a simple matter to calculate the appropriate PSC value
based on a degree value and adjusted by the limits of the particular
servo.
Does anyone know the math for this off hand?
can use.
servo.
translation could do it:
(((max-min)/180)*degrees)+min
but the stamp does not do floating point so there must be a way to
handle it.
Anyone want to take a shot at this one?
that correspond to 0 - 180 degrees. The solution is a simple mx + b
equation:
command = degrees * 5.555 + 250
Before you panic, the BASIC Stamp can if fact multiply by fractional
values (the result will be an integer). There are two operators that
can be used, we'll use */ (star-slash). To use star-slash, multiply
your fractional value by 256, then apply it as the parameter. The
equation above becomes:
command = degrees */ $058E + 250
I prefer hex when using */ because I can see the whole portion in the
upper byte, the fractional portion in the lower byte. The BASIC Stamp
doesn't care what numeric format we use; it's all the same inside.
For those that need more resolution in fractional values, you can use
the ** operator. With it you are able to multiply by a value less that
one in units of 1/65536. Both operators are in the help file.
Does everyone know there is a new installer and separate help file
available on our web site?
http://www.parallax.com/html_pages/downloads/software/software_basic_sta
mp.asp
-- Jon Williams
-- Dallas Office
From: Dave Evartt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=dtgta2JMFDY0A-gPaID-D_XeWYsvpXBb2633qVbmf_iNoVKS-_PL2Cu9TkbWW2BZEpxPFm7spDecGaeNNYs]davee@f...[/url
Sent: Monday, July 12, 2004 8:13 AM
Subject: [noparse][[/noparse]basicstamps] PSC data conversion
can use.
servo.
Not knowing that much about the PSC, is the 0-180 range always 1000?
Assuming that the servo can always travel 180 degree.
My experience is that there are always little discrepancies between
servos and I've learned not to trust the hard coded numbers.
For instance, 770 is shown as what is considered 'center' but in
real life it varies by quite a bit. Is that variance consistant
wonce you determine one partitular angle? If that is the case than
the 5.555 can be cast in stone and that's fine by me.
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> This is actaully pretty easy. Commands to the PSC range from 250 -
1250
> equation:
fractional
that
multiply
the
Stamp
use
that
sta
> mp.asp
> -- Jon Williams
> -- Dallas Office
> From: Dave Evartt [noparse][[/noparse]mailto:davee@f...]
> can use.
we
value
particular
> servo.
I haven't personally used the PSC -- I responded to your question using
the documentation provided. You're right in that servos will vary, and
the docs even mention this. You'll need to work with your servos to
find the endpoints and center. From there you can adust the equation.
-- Jon Williams
-- Dallas Office
From: Dave Evartt [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jJPXDF3Rix9-kd8Owfwal-1qgds_ayI4WfTdT31QwQak_sjLtcGSADZdoRPQ1D3Uw80UwZPvvQ41zQBPpTNVintYHg]davee@f...[/url
Sent: Monday, July 12, 2004 10:30 AM
Subject: [noparse][[/noparse]basicstamps] Re: PSC data conversion
Thanks Jon,
1250
> equation:
fractional
that
multiply
the
Stamp
use
that
sta
> mp.asp
> -- Jon Williams
> -- Dallas Office
> can use.
we
value
particular
> servo.
You can find the */ factor at run time,
(degrees*256/180) */ (PSCmax-PSCmin) + PSCmin
(degrees/180) will be between 0 and 1 when degrees is between 0 and
179, so (degrees*256/180) will be proportionately between 0 and 256,
and */ gets the same proportion of the difference (PSCmax-PSCmin).
-- Tracy
>Thanks Jon,
> 1250
> > equation:
>fractional
>that
>multiply
>the
>Stamp
>use
>that
>sta
> > mp.asp
> > -- Jon Williams
> > -- Dallas Office
> > can use.
>we
>value
>particular
> > servo.
needs to be calculated by MAX-MIN and then devide THAT number by
180. That's what I don't know how to do on the stamp.
once again please: (((MAX-MIN)/180)*DEGREES)+MIN
(it would be so nice if the compiler could handle the conversion of
the math but it's a lot to ask.)
wrote:
> Dave,
using
vary, and
to
equation.
> -- Jon Williams
> -- Dallas Office
> Thanks Jon,
1000?
between
<jwilliams@p...>
250 -
> 1250
+ b
> > equation:
> fractional
> that
> multiply
The
> the
> Stamp
inside.
> use
less
> that
file
> sta
> > mp.asp
> > -- Jon Williams
> > -- Dallas Office
PSC
> > can use.
> we
degrees)
> value
> particular
> > servo.
Between you and Jon, you both make it easy. Can't wait till I get
home tonight to try it.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Dave,
and
256,
> -- Tracy
> >Thanks Jon,
1000?
between
<jwilliams@p...>
250 -
> > 1250
mx + b
> > > equation:
> >fractional
operators
> >that
> >multiply
parameter. The
portion in
> >the
BASIC
> >Stamp
inside.
can
> >use
less
> >that
file
_
> >sta
> > > mp.asp
> > > -- Jon Williams
> > > -- Dallas Office
commands to
the PSC
> > > can use.
calibration,
> >we
degrees)
> >value
> >particular
> > > servo.
see until after I wrote this message.
--- In basicstamps@yahoogroups.com, "Dave Evartt" <davee@f...> wrote:
> that's why you can't assume that the 5.555 is a good number, it
of
<jwilliams@p...>
> wrote:
> > Dave,
question
> using
> vary, and
servos
> to
> equation.
> > -- Jon Williams
> > -- Dallas Office
> > Thanks Jon,
> 1000?
> between
than
> <jwilliams@p...>
> 250 -
> > 1250
mx
> + b
> > > equation:
> > fractional
operators
> > that
> > multiply
> The
in
> > the
BASIC
> > Stamp
> inside.
can
> > use
> less
> > that
> file
> > sta
> > > mp.asp
> > > -- Jon Williams
> > > -- Dallas Office
to
> PSC
> > > can use.
calibration,
> > we
> degrees)
> > value
> > particular
> > > servo.
Suppose degrees=77, for example. The idea behind the */ operator is
to approximate your fraction, 77/180, by the fraction 109/256.
Calculate it out. You will see that they are the same number, 0.427
(as close as can be done with the denominator 256).
When the stamp computes {x = 109 */ (PSCmax-PSCmin)}, it multiplies
the numbers together internally in a 32 bit workspace, and then
shifts the result 8 bits to the right. That is equivalent to
dividing by 256, making the whole thing, 109/256. In summary, {x =
109 */ (PSCmax-PSCmin)} is the same as {x = 0.426 * (PSCmax-PSCmin)}
on a calculator.
The calculation (degrees*256/180) takes 77 as its input and gives 109
as its output. It is in effect solving for y in, y/256 = 77/180.
That is the same relation you or the Stamp would have to solve to
find the factor to go with the */. If you knew degrees=77 in advance
at compile time, then you would just use y= 77/180 * 256 = 0.426 *
256 = 109. But in your situation, degrees is a variable. The stamp
has to do it in this order, (degrees * 256 / 180), so that degrees *
256 will be a large number that can be divided by 180. If the stamp
did it this other way, (degrees / 180 * 256), it would always come
out zero.
There are other ways to find the answer, but */ seems good for this situation.
-- Tracy
>Thanks tracy. I don't quite understand it but if it works, cool.
>> Hi Dave,
>and
>256,
>> -- Tracy
>> >Thanks Jon,
>1000?
>between
><jwilliams@p...>
>250 -
>> > 1250
>mx + b
>> > > equation:
>> >fractional
>operators
>> >that
>> >multiply
>parameter. The
>portion in
>> >the
>BASIC
>> >Stamp
>inside.
>can
>> >use
>less
>> >that
>file
>_
>> >sta
>> > > mp.asp
>> > > -- Jon Williams
>> > > -- Dallas Office
>commands to
>the PSC
>> > > can use.
>calibration,
>> >we
>degrees)
>> >value
>> >particular
>> > > servo.
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
robot controller that uses the PSC to control the servos. The BS2P
is the interface between the serial port on the computer and the
whole thing.
All I have to do is send joint commands that consist of the first
letter of the joint and a 0-180 value and the joint rotates there
very nicely.
s90
e90
w0
puts it into a nice 90 degree configuration
__
I wonder what I'll do tomorrow [noparse]:)[/noparse]
Thanks again, and thanks for the explanation.
> There should be no big mystery in the */ operator.
is
0.427
multiplies
PSCmin)}
> on a calculator.
109
advance
stamp
stamp
> out zero.
this situation.
> -- Tracy
wrote:
> >> Hi Dave,
> >and
> >256,
PSCmin).
> >> -- Tracy
> >> >Thanks Jon,
> >1000?
> >between
in
consistant
than
> ><jwilliams@p...>
from
> >250 -
> >> > 1250
simple
> >mx + b
> >> > > equation:
> >> >fractional
> >operators
> >> >that
slash,
> >> >multiply
> >parameter. The
> >portion in
> >> >the
> >BASIC
> >> >Stamp
> >inside.
you
> >can
> >> >use
value
> >less
> >> >that
file.
help
> >file
c
> >_
> >> >sta
> >> > > mp.asp
> >> > > -- Jon Williams
> >> > > -- Dallas Office
> >commands to
> >the PSC
> >> > > can use.
> >calibration,
> >> >we
> >degrees)
PSC
> >> >value
> >> >particular
> >> > > servo.
> >Yahoo! Groups Links
