BS2P Alternate Bank Labels
In a message dated 7/9/2004 3:08:22 PM Eastern Daylight Time,
knight_designs@y... writes:
> My problem, is now that I moved the DATA statements to BANK 1 I ca't
> use DispAdd = [noparse][[/noparse]DATA Label]
> If I specify the exact address in the BANK 1 area, everything works,
> but I can't think how to simplify this. Jon?
Anyone??
Do your have all the variables and constants in Bank 0 also in Bank 1 in
EXACTLY the same physical order?
Sid
Sid
did something that should be simple, and my brains are fried and I
can't think of what I am supposed to do. I'll explain...
Using the BS2P40, I had code with text defined in data statements:
Disp01 DATA "Text Label One"
Disp02 DATA "Text Label Two"
Disp03 DATA "Text Label Three"
etc.
I recently moved these to another bank to conserve code space,
however, the way I wrote my print routine (Which is similar to all
my previous code) is:
First set the address to the DATA address:
DispAdd = Disp01
Then call the Display Subroutine:
Display:
READ DispAdd, Disp
IF Disp = 0 THEN DispExit
LCDOUT 0, DisplayOn, [noparse][[/noparse]Disp]
DispAdd = DispAdd + 1
goto Display
DispExit:
RETURN
Knight Designs
how I've solved that problem in my projects.
1) Decide on a maximum length message -- if you're using a 16-character
LCD, for example, you don't to have messages any long than that.
2) Structure your external DATA labels so they fall on even boundaries.
What I do, just because it's easy, is this:
Disp01 DATA @$00, "Text Label One", 0
Disp02 DATA @$10, "Text Label Two", 0
Disp03 DATA $$20, "Text Label Three", 0
With this setup, the first message is at address 0, the second at
address $10 (16), etc.
3) Instead of using a direct Label, you'll now use a message number and
the max length to calculate the address:
msgAddr = msgNum * MsgLen
4) Adjust your print routine as follows:
Print_Msg:
STORE msgBank
chOffset = 0
DO
READ (msgAddr + chOffset), char
chOffset = chOffset + 1
IF (char = 0) THEN EXIT
LCDOUT 0, DisplayOn, [noparse][[/noparse]char]
LOOP UNTIL (chOffset = MsgLen)
RETURN
This may, perhaps, look more sophisticated that it needs to be, but
there are reasons for my madness: the way this code works it will point
to the bank that has your messages (this is a great technique for
multilingual apps), then read characters from the string you've pointed
to. The loop will run until it hits a zero in the stream or hits the
maximum message length.
You can still use constants to make this code readable, for example:
Msg1 CON 0
Then....
msgNum = Msg1
GOSUB Print_Msg
I hope this helps.
-- Jon Williams
-- Dallas Office
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=gdj1yjzhQDyeHLQ5N9Yx4aink8TGBfnZk_E_556k-dEjmstkvChW6crq-hcxs6CxH8mmqFug3qV8GxEtlTqz]knight_designs@y...[/url
Sent: Friday, July 09, 2004 2:07 PM
Subject: [noparse][[/noparse]basicstamps] BS2P Alternate Bank Labels
I think I've been working too long and hard today, because I just
etc.
DispAdd = Disp01
Display:
READ DispAdd, Disp
goto Display
DispExit:
RETURN
Knight Designs
another bank. You can certainly use labels in any bank, but they're
only visible to code that lives in the same bank.
Sorry for any confusion.
-- Jon Williams
-- Dallas Office
Sent: Friday, July 09, 2004 2:23 PM
Subject: RE: [noparse][[/noparse]basicstamps] BS2P Alternate Bank Labels
You're right, Chris, you can't use DATA labels in another bank. Here's
Print_Msg:
STORE msgBank
chOffset = 0
DO
RETURN
Msg1 CON 0
Then....
msgNum = Msg1
GOSUB Print_Msg
I hope this helps.
-- Jon Williams
-- Dallas Office
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DBJc0izYn7gfxQBm4o5QdKn7TWeY6yDLNLB66TEDeFd5iKhWta6VCcPz5P136IQ1sKHQROXLramyNHIN4B6q3A]knight_designs@y...[/url
etc.
DispAdd = Disp01
Display:
READ DispAdd, Disp
goto Display
DispExit:
RETURN
Knight Designs
Bank 1 in
> Sid
Well, everything's in Bank 0 EXCEPT the DATA statements. For some
reason I thought I was missing something that would let me use my
Labels as pointers (Addresses), but from the next message, I see Jon
has a solution to simplify what I am already doing, which is
specifying absolute addresses.
Knight Designs
resolved at compile time, and the compiler can only handle one file at a
time.
-- Jon Williams
-- Dallas Office
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_dOpnR718wIQhIOUq_hdGdGHZmftlyDl8cw6JBQSphFcRdgdMG1OrGFOaTg0pnhRd-aIWQ-cQ8ZDkIGpdRClOaWAlA]knight_designs@y...[/url
Sent: Friday, July 09, 2004 2:41 PM
Subject: [noparse][[/noparse]basicstamps] Re: BS2P Alternate Bank Labels
Bank 1 in
> Sid
Knight Designs
Here's
character
boundaries.
--- TRIMMED ---
Okay Jon, I get the idea...I don't think I will end up having so
much text/data that I can't afford to do that. For some reason I
was just sure I was "missing" something. Even boundries for the
text sounds great. Since I am using a 20 X 4 LCD Display, then I
would be using a maximum of 20 characters per data statement, plus
the 0 terminator byte. SO I could go @$00, @$20, etc. giving me 32
bytes per statement.
Anyway, thanks for the help. Just got everything ported over to a
new Laptop, and had to turn around and get a USB2Serial from you
guys (Parallax) since THIS Laptop doesn't have a Serial Port.
Speaking of the FTDI USB2232 converter, regardless of what the
instructions on the Website say, this thing is Plug & Play under
Windows XP. At least if you have SP1 or hgiher. No need to
download the drivers from the site. And no messing around with FIFO
settings to get things to work on the laptop. Not to mention, the
LEDs give good feedback that there's activity on the serial lines.
Knight Designs
Msg1 DATA "Short message", 0
Msg2 DATA "This is a long message and doesn't play nice with
boundaries.", 0
Msg3 DATA "Another shorty", 0
Back in the main program bank you can add this:
Find_Msg:
STORE msgBank
IF (msgNum > 0) THEN
msgAddr = 0
zCount = 0
DO
READ msgAddr, char
msgAddr = msgAddr + 1
IF (char = 0) THEN zCount = zCount + 1
LOOP UNTIL (zCount = msgNum)
END
At this point msgAddr holds the address of the first character of the
selected message and you can print it as before.
-- Jon Williams
-- Dallas Office
From: Chris Savage [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=IyKfwEF_oUFLCe8hRBbTvsN5tKDmZzh-VtGecIO4y2n2XmxZ3W9WqIDGR4r6ZsV0NwWsmlbMdZBfnuw_nsbDnw]knight_designs@y...[/url
Sent: Friday, July 09, 2004 2:51 PM
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
Here's
character
boundaries.
--- TRIMMED ---
Knight Designs
Another method is to to store the DATA in one bank and also declare
the same labels as constants in the bank where the routine is:
Disp01 CON 0 ' 15 "Text Label One",0
Disp02 CON 15 ' 15 "Text Label Two",0
Disp03 CON 15+15 ' 17 "Text Label Three",0
Disp03 CON 15+15+17 ' 16 "Text Label four",0
Don't forget to count the null delimiter. The advantage is that you
get to refer to your messages by name, the disadvantage is that you
have to count the characters and update the constants if you change
the DATA.
Another solution is to move the small routine that displays the data
to the other bank along with the DATA. Then use a cross-bank call
for the display. That would probably involve an indexing scheme like
Jon suggested to pick the message to be displayed.
-- Tracy
>etc.
>DispAdd = Disp01
>Display:
> READ DispAdd, Disp
> goto Display
>DispExit:
> RETURN
>Chris Savage
>Knight Designs
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
wrote:
> There is a way to compress messages in the external bank:
> boundaries.", 0
---TRIMMED---
Jon,
I tried to reply to this when you wrote it, but Yahoo was acting
up again. Anyway I'm home now, but what I was going to say was, to
show you how burned out I was at work today, I had to read your
message twice to see what you were doing, and how.
Tomorrow's another day...Thanks again for the help.
Knight Designs
> Hi Chris,
declare
you
you
change
> the DATA.
Hi Tracy,
Before I tried anything I read Jon's article on Multi-bank
programming, then read the one on your website. Having programmed
for almost 20 years, I find it hard to change my style, so the stack
pushing/pulling thing wasn't for me (YET!)...However, I did try
something similar to what you posted, but ultimately went with Jon's
original idea, which just simplified my own code, which is what I
culdn't think of at the time.
data
like
One of these days I am going to have to actually break yours and
Jon's multi-bank stuff down and see what really works for me. Seems
not to long ago someone mentioned doing something similar, and the
list got on the subject, and I can't remember exactly, but do you
need to save the variables, or do they remain intact if you simply
switch banks, and the program has all the exact same declarations &
variables? Seems to me that would be another option for someone
like me who uses modular programming using an "overlay" of sub-
routines.
Knight Designs
