Bicycle roller racing computer
A regular bike computer would work but you missed one small detail......He
wants to display parameters on large led displays so both riders can see what
the others speed/distance is.
I am a cyclist, and a stamp user. Your concerns are certainly valid. If I
were to approach this type of project, I would use an external counter, and I
highly recommend a MAX7219, which is one IC that will easily handle 8 seven
segmet displays.
Write back if more information/detail is needed. The data sheet for the
MAX7219 can be a little intimidating, but I have broken it down into simple
english......the device is actually easy to use.
Ken
Not sure I'm visualizing this - If the wheels are turning
would'nt a regular bike speedo/odo work?
Sounds pretty neat...
regards, Jack
leverphysics wrote:
> I am planning to build a computer that keeps track of average speed,
> instantaneous speed, and total distance travelled by each of 2
> bicycles when riding on a pair of rollers. The data for each
> cyclist would be displayed on large LED displays. This would allow
> the riders (my son and I) to have some fun competing on simulated
> road rides during long New England winters.
segmet displays.
Ken
regards, Jack
For any of you who are not familiar with rollers, they consist of
three horizontal cylinders mounted in a frame that rests on the
floor. A bicycle can be ridden on top of the rollers, allowing a
cyclist to get a great workout using his/her own bike. Because the
bike must be steered to stay upright, it is a lot more realistic and
fun to ride than a stationary bike.
Anyway, I am thinking of mounting magnets on one end of a roller on
each set. I could then count rotations using Hall sensors. Knowing
the rotations, applying the appropriate conversions, and clocking
elapsed time would allow computation of speeds and distances. I
hope to do all of this using a BS2. I plan to use a large 3-digit 7-
element LED display and 1 decimal point for each of the two
cyclists. The displays could be toggled between metric and english
units.
I am concerned about the ability of the program to count each and
every rotation of the two independent rollers. Would it unburden
the software to use some sort of hardware counter that could then be
polled when the software was ready? Does anyone have suggestions on
what digital IC might be helpful to accomplish this?
I could also use suggestions on how to drive the displays, and
advice on the feasibility of using a single BS2 for both rollers
rather than one for each.
Thanks!
Rich
regards, Jack
> units.
> Thanks!
> Rich
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Good point. The difference is that the system I would like to build
provides 2 heads-up displays, making it easy for two riders to race
against each others "data", so to speak. For example, two riders
could toggle to instantaneous speed display and see who has the
longest and fastest sprint, or they could have a 50 km road race -
the first to reach 50 km wins. The opponent would always know how
far ahead or behind he is placed. The standard handlbar mount
display can only be seen by the rider of that bicycle.
Rich
> regards, Jack
speed,
allow
the
and
on
Knowing
digit 7-
english
> > units.
then be
suggestions on
> > Thanks!
> > Rich
> > Yahoo! Groups Links
>Hi Jack:
>Rich
Rich -
I would rather doubt that one Stamp could adequately track two bicycles due to the time required to field the rotational data from the rollers. The cost of the STAMP processor(s) is probably going to be the largest part of the cost of this project. You MIGHT be able to provide yourself more time if you were tracking the rotation of the bicycle wheel rather than the speed of the rollers. Depending on the diameter of the rollers, and the diameter of the tires. you might be talking a ratio of 30:1, more or less. That would buy you a good deal more "free time" outside of the actual data acquisition.
That being said, and presuming that there will then be one Stamp for each bicycle, then two readouts (one for each cyclist) makes more sense to me. To my way of thinking, the next step is to allow either Stamp to display on either readout, at the individual cyclist's discretion. Now expand the thinking a bit beyond 7-segment displays to a large format character LCD, or a 2 line character LCD, both of which might do well to be of the serial input variety. Now a simple SPDT or DPDT switch could determine which set of data was being viewed since you're only switching the data line. There is a screen clearing issue to be worked out, but I don't see that as insurmountable.
Just some additional thoughts.
Bruce Bates
with tossing a couple tachometers in there and just have the stamp A/D them
in and also run it with a timing unit (can't remember the number DS
something or other).
Even the computers that are already made for bikes are not real time....they
update every second or so. You could easily update 2 displays and read 2
tachs within 3 seconds.
And you could also forecast or average (depending what you really want) and
make up for that time in between actual measurements.
With a 3 second update you could do alot. put some gear sensors on there
and figure out what gear you're in....yup yup....unless I'm missing
something!
Sent: Friday, July 09, 2004 1:38 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Bicycle roller racing computer
> At 02:18 AM 7/9/04 +0000, leverphysics wrote:
> >Hi Jack:
> >Rich
> Rich -
insurmountable.
> Regards,
> Bruce Bates
> Yahoo! Groups Links
Best twist yet!!!
But I have what I think is even a better idea.........
Quit your job, uproot your family and move here to sunny southern
california.....
No smog ,no crime, everybody is VERY friendly, cars don't try to run you off
the road, etc.......but we can ride all year long.....well almost. Last
winter I had to go about 5 days once between rides because of rain.
Seriously though, I like the video text overlay idea.
Ken
That sounds like an interesting project. I have a suggestion to make
it more interesting. Since you want a big display, you could use one
of the BOB video text overlay boards to display your data on a TV
screen. Before the winter hits, you could spend a fall weekend
videotaping your favorite New England bike riding roads.
... two months elapse while debugging the code etc ...
When the snow flies, you pop in a tape and have a virtual bike ride
while the data shows up on the screen.
Have fun.
Lee
Have fun.
Lee
--- In basicstamps@yahoogroups.com, "leverphysics" <rlever@m...>
wrote:
> Hi everyone:
speed,
and
Knowing
> units.
be
on
> Thanks!
> Rich
> wrote:
> > Hi everyone:
> speed,
allow
**snip**
> > Thanks!
> > Rich
Those cycle computers use a magnetic reed switch in them, might be
simpler than "hall effect"
Have fun Gary B.
