Interface USB memstick to bs2?
In a message dated 7/3/2004 4:19:54 PM Eastern Daylight Time,
dntgvasht@y... writes:
> I have a rather large program to make, and just putting in the
> dialogs has completely filled the eeprom mem on the stamp. I want to
> interface the stamp with an eeprom usb memory stick, to hold program
> dialog data which will free up onboard eeprom for the actual
> program. Does anyone have any information that will help me
> interface with a usb memstick? interfacing, protocols, timing,
> anything will help.
First off, you can not store program code anywhere but on the Stamp itself.
A BS2E has storage for 16K of program - eight 2K slots. If you need more
room than that then I wouldn't know where to tell you to look.
Sid
> anything will help.
Sid
anything will help.
why usb? well it's relatively available, cheap, and uses only 2 I/O
pins.
I have heard that interfacing with USB is a nightmare though, so if
anyone has an alternate way of storing the data, please educate me.
You could use the BS2p or the BS2pe which have 8 or 16 banks of EEPROM
memory respectivly. That is 16kBytes or 32 kBytes instead of the 2 kB a BS2
has.
Regards and success,
Klaus
Sent: Saturday, July 03, 2004 9:12 PM
Subject: [noparse][[/noparse]basicstamps] Interface USB memstick to bs2?
> anything will help.
> pins.
> Yahoo! Groups Links
only be used with READ and WRITE instructions (use STORE to point to the
required bank).
Jon Williams
Parallax
From: K de Jong [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=QHQuArSWKpfOoicqxMR0s97HCOYKPxtCKhpPs780MBG2H1dMJfmyWdxKej696IXT9_bUgPitK2Q5]klaus0@x...[/url
Sent: Saturday, July 03, 2004 4:23 PM
Subject: Re: [noparse][[/noparse]basicstamps] Interface USB memstick to bs2?
BS2 has.
Klaus
> I have a rather large program to make, and just putting in the dialogs
> dialog data which will free up onboard eeprom for the actual program.
> Does anyone have any information that will help me interface with a
> usb memstick? interfacing, protocols, timing, anything will help.
> pins.
> and
> Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I understand that program code can only be in the stamp, but having a pointer to an external memory address is much more space saving than putting long dialogs into the stamp memory.
For example, the stamp communicates with an external device, and the device returns error code &H03. The stamp then searches the external memory for the verbose string referenced by &H03, and that string is relayed to an LCD panel. I have many hundreds of such strings and interface dialogs that must be used. Also, using a USB memstick would enable on-the-fly configuration changes for different devices I connect to.
I have begun looking at possibly using playstation memory cards as an alternative to USB memsticks. Seems they might be easier to interface.
--- In basicstamps@yahoogroups.com, "K de Jong" <klaus0@x> wrote:
> Hi,
> has.
> Klaus
> From: <dntgvasht@y...>
> > anything will help.
> > pins.
> > Yahoo! Groups Links
BS2p and BS2pe have I2C instructions built in. I would look there and
forget about the USB thing.
Jon Williams
Parallax
From: dntgvasht@y... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=HpOA4lMPt0HDzqFkO2Bry0UqkHJi5ctk7wDD35K0Qj7edOS76jQL6J4w0uR0tt-X3dKzOxY_S0LLw-y4l4M]dntgvasht@y...[/url
Sent: Saturday, July 03, 2004 2:13 PM
anything will help.
pins.
MAXIM 28L64 is a number that sounds correct...
to
program
> anything will help.
I/O
> pins.
