Syntax help? SPSTR
At 08:17 AM 7/3/04 +0000, LostboY wrote:
>I know you are probably sick of hearing about this SPSTR issue, but
>can you tell me what is wrong with this line:
>SERIN 7, 84, 60, Hard_Reset, [noparse][[/noparse]SPSTR 64]
>Where the timeout is 60 ms, Hard_Reset is where it branches if there
>is a timeout, and [noparse][[/noparse]SPSTR 64] should look to get 64 bytes that are
>placed into scratch pad, starting at location 0.
>I have the correct directive: '{$STAMP BS2e}
>I am using the Basic stamp editor version 2.1 beta 1. When I check
>the syntax of the above, it highlights the SPSTR and says that it
>expects a variable.
>Help?
>Thanks,
>Ryan
Ryan -
For better or worse, I can verify that the same error occurs on the PBASIC Version 2.0 compiler both with your program example, and those recently supplied by Jon Williams in this same thread. I suspect you can temporarily circumvent the problem by using a Stamp Directive which look like this:
'{$STAMP BS2pe}
I realize this isn't representative of the Stamp Model that you are presently using, but I suspect it will work without any untoward effects.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
>expects a variable.
>Help?
>Thanks,
>Ryan
Ryan -
'{$STAMP BS2pe}
Bruce Bates
>Yahoo! Groups Links
-- Jon Williams
-- Dallas Office
From: LostboY [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=7-p-t4ai1k6HJn1sEjjyPMCK3hJmbBEEaTNXP8Yr4MJaMkxXEWwOBVJCp6k1FVHdoXn3yTbpK23VMdU]hangook21@y...[/url
Sent: Saturday, July 03, 2004 3:17 AM
Subject: [noparse][[/noparse]basicstamps] Syntax help? SPSTR
expects a variable.
Help?
Ryan
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
contain an alternate method of doing what you want
Shawn
> [noparse][[/noparse]Original Message]
> expects a variable.
> Help?
> Thanks,
> Ryan
