new member, RC Time accuracy
Hello Everyone,
I am using the BS2p demo board and utilizing the RC time
capabilities. Is there any way to increase the accuracy of the RC
time measurement? My results vary +/- 200 units. My R is 20k and my
C is .1 uF, and I am reading anywhere from 22k to 18k, which isn't
accurate enough for my application. Any suggestions? Thanks
really good components and you will get more consistent results.
Jon Williams
Parallax
From: steven_hunting [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=P7BYAyp55d9XrrF595GVMEo2l9FzBrkoC2gBErGAKHZdGI6JSTiame4qpHPOuZdxUZu5JrNE1EV-qWc]shunting@l...[/url
Sent: Friday, July 02, 2004 3:07 PM
Subject: [noparse][[/noparse]basicstamps] new member, RC Time accuracy
Hello Everyone,
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
Jon, is it likely that the value of the components are varying that much
in real time? Seems to me that one should at least get a stable value with
a fixed error.
Tom Fisher
Jon Williams
Parallax
From: TBooneFisher [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=FmRzKd0rODon26htdkXcb-PVUvdHyUQ62lo5V0XA1lhjzbOTdPiXP4MWYWEXKk5puAfFuQzZdQGlp0mcQfiQUg]tboonefisher@s...[/url
Sent: Friday, July 02, 2004 7:07 PM
Subject: Re: [noparse][[/noparse]basicstamps] new member, RC Time accuracy
> The problem is NOT the BASIC Stamp -- it's your RC components. Use
much in real time? Seems to me that one should at least get a stable
value with a fixed error. Tom Fisher
Yahoo! Groups Links
abuse@p....
Does even a "sloppy" capacitor's value vary from second to
second?
Tom Fisher
Take a look at this URL about fine points and applications of the
RCtime command...
http://www.emesystems.com/BS2rct.htm
especially the part about errors and noise.
You may be able to improve the performance by changing your circuit
layout. Look for a better, shorter ground path for the capacitor,
with respect to Stamp ground. Ground loop voltages generated by
digital operation of the Stamp and other circuits create a noisy
switching threshold that makes your RCtime value jump up and down
erratically. It is not possible to eliminate it completely, but it
should be good for about 8--10 bits of accuracy with good layout.
Use a film capacitor and resistor for best stability.
You can even accentuate the noise effect by making a long ground loop
on your capacitor, on purpose, and pick off RCtime values modulo 100
as a random number generator.
-- Tracy
>Hello Everyone,
> RCtime command...
Outstanding reference, Tracy. Thanks! Especially the section
about using RCTIME to monitor a voltage source. I will use this
in my heater controller instead of an ADC.
Tom Fisher
