Nuts & Volts - ideas for articles
One of the re-occuring threads on here is how to use a MOSFET and how
to connect a relay.
I'm not sure if you can 'review' the basics on a column.
another idea is LED's.
there is an occasinal question as to how to pulse and LED to get
higher brightness or use multiple LED's on on pin.
connecting an LED on a switch input or relay/transistor output.
It is neat to have an opto or switch input and corresponding LED to
indicate the status of the input. ditto for transistor and relay
outputs.
These may be simple articles but it seems the ideas have some
application.
Another article that would be more education than anything else is
how to read a product spec sheet. That may be way too extensive for
one article.
Another item I rean across recently was how to wire an alarm
circuit. What is the best way to wire the switches and how do you
know if the switch is the correct state or the wire is cut/shorted.
And of course there is the timing of stamps and stacks and pause and
timing loops.....
Dave
to connect a relay.
outputs.
application.
one article.
timing loops.....
Dave
flavors of PWM. H-Bridges seem to appear on a regular basis as well in the
stamp forum.
>to connect a relay.
>outputs.
>application.
>one article.
>timing loops.....
>Dave
Beau Schwabe Mask Designer II National Semiconductor Corporation
500 Pinnacle Court, Suite 525
Mail Stop GA1
There are other areas of the magazine that cover those things.
Jon
From: Dave Mucha [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=equkF2GsWrfvtpg3FGFC2qkkd1e0Z6DS0czOL8rRYt4_yhQUXg40EM5enXBL-8oIe_mCndkibvNQTWGz]davemucha@j...[/url
Sent: Friday, July 02, 2004 2:03 PM
Subject: [noparse][[/noparse]basicstamps] Re: Nuts & Volts - ideas for articles
to connect a relay.
connecting an LED on a switch input or relay/transistor output. It is
outputs.
application.
one article.
timing loops.....
Dave
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
and degree turns! You have the hardware now!
http://www.parallax.com/detail.asp?product_id=28107
Rick
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> My column has more to do with embedded programming than with
hardware.
> Jon
