Sensirion Temperature/Humidity Sensor
What precautions do I need to take to protect the Sensirion
Temperature/Humidity Sensor when using it outdoors? I have not been
able to locate any data on this.
Thanks for your time and help!
protective shelter (that lets air circulate). For obvious reasons, you
don't want to expose it to direct sunlight or moister (rain, sprinklers,
etc.).
-- Jon Williams
-- Dallas Office
From: hbpate [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=33-XvaWy_WkuavQ5lA-uxfRqrNdiYECpl6QNtNkqKAM8a01pZXt0FYc4u7KcuDE3UuQ5mW_ZABRzT8I]hbpate@m...[/url
Sent: Friday, July 02, 2004 9:02 AM
Subject: [noparse][[/noparse]basicstamps] Sensirion Temperature/Humidity Sensor
protect the sensor from harsh conditions. The worst conditions are
those where caustic materials are floating around, such as the marine
environment with salt or the agricultural environment with sulfur
sprays, or a heavy traffic environment with smog. That is where the
membrane would be helpful.
In less harsh conditions, like Jon said, just protect it from direct
exposure to the elements. A PVC cap/roof with a screen cover on the
open end may be all the protection you need. You usually want the
temperature/humidity in the shade, away from the effects of radiation
from the sky or from the ground. Ventilated radiation shields like
the Davis 7714 are good, but you will always get the best result from
a large but open shaded area.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
>Like any other temp/humidity sensing instrument it should be placed in a
>etc.).
>-- Jon Williams
>-- Dallas Office
>From: hbpate [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2FHArWhRMzvhZCOe1CVnfjUNSWMox3xTLfWVFfYLGGDqJ0hA-xIYuNeBiQ_wvd6Us_mJuvsPAK0O8jM]hbpate@m...[/url
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Yahoo! Groups Links
Just a quick note: Not sure if there is anyway to protect this device from
lightning, but I got one blown out by secondary voltage from a nearby strike
while I had it mounted outside on the north side of my house, and it wiped
out the two ports I was using on the stamp to run it. The rest of the stamp
ports were OK. Anyway, might be a good idea to disconnect it (sensiron
sensor) from the stamp when there is outside electrical activity. As Jon
and Tracy indicated, I had it mounted inside a pill bottle with a screen on
one end pointed downward to keep rain from getting into it. It worked great
until the lightning strike!
Sent: Friday, July 02, 2004 14:44 PM
Subject: RE: [noparse][[/noparse]basicstamps] Sensirion Temperature/Humidity Sensor
> Sensirion will be introducing a membrane (gortex?) to cover and
> -- best regards
> Tracy Allen
> mailto:tracy@e...
> >etc.).
> >-- Jon Williams
> >-- Dallas Office
> >From: hbpate [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=DDjIjPUf1Nj59SaShEcblR0AY3ZfQc03gWJTEDnMYapr2c9m1KgoDJAvo8d6BmrjVX5eHF13B_JSfT4]hbpate@m...[/url
> >Yahoo! Groups Links
> Yahoo! Groups Links
us folks out.
Wish I could find screen wire with a small enough mesh to keep ants
out.
marine
the
direct
the
radiation
from
> -- best regards
> Tracy Allen
> mailto:tracy@e...
placed in a
reasons, you
sprinklers,
> >etc.).
> >-- Jon Williams
> >-- Dallas Office
> >From: hbpate [noparse][[/noparse]mailto:hbpate@m...]
> >Yahoo! Groups Links
>Thanks to everyone for the help! I love it when the true experts help
>us folks out.
>out.
Try looking for some sifting mesh not unlike this:
http://www.screentg.com/square22.htm
It comes in all sorts of sizes, large mesh and small mesh.
Bruce Bates
>marine
>the
>direct
>the
>radiation
>from
>> -- best regards
>> Tracy Allen
>> mailto:tracy@e...
>placed in a
>reasons, you
>sprinklers,
>> >etc.).
>> >-- Jon Williams
>> >-- Dallas Office
>> >Yahoo! Groups Links
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
