12 bit DAC
In a message dated 6/30/2004 8:13:05 AM Eastern Daylight Time,
grover.richardson@g... writes:
> LTC1298CN8 12 Bit A-d, 3 wire serial $9.88 from Digikey
> Good documentation with example code available (from Parallax) that works
> the first time<G>. Nice beast.
He was asking for a DAC.
Sid
Sid
I'd like to look at both, voltage output and also a 4-20ma output.
Web Searches pull up numerous results but I was curious to what some of you
folks have used successfully.
Richard
From: Richard [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8YVETT67mGUrmeWVy9Dtu5tkaa056_nC5aN-mxlT8-AcQim0eDxLnY8fCjFadgO1kJkb_jTqq38fENz6-WSBMpgh]rwskinner@a...[/url
Sent: Wednesday, June 30, 2004 7:31 AM
Subject: [noparse][[/noparse]basicstamps] 12 bit DAC
Can anyone recommend a good, easy to interface, 12 bit Dac for the Stamp?
Richard
Yahoo! Groups Links
From: Newzed@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=45G32PcXGX4DHIxNVEPFAi7psz2BapGt0DSGyy4PLA8oiRerSuojANNDExSg0uOxsOFSt6D3ULnJ]Newzed@a...[/url
Sent: Wednesday, June 30, 2004 8:14 AM
Subject: Re: [noparse][[/noparse]basicstamps] 12 bit DAC
> works the first time<G>. Nice beast.
Sid
Yahoo! Groups Links
Perhaps one of these would fit:
MAX531 / 538 / 539 - Single 12-bit voltage out
DAC7611 - Single serial 12-bit voltage out
DAC7612 - Dual serial 12-bit voltage out
DAC7624 - Quad serial 12-bit voltage out
DAC 8501 - Single serial 16bit voltage out, Rail-to-Rail (pretty cheap @ ~
$10)
Haven't used any of them, hope it helps though.....
/Henrik Olsson
Sent: Wednesday, June 30, 2004 1:31 PM
you
> Thanks,
> Richard
Analog Devices AD421 is a 16 bit DAC with 3 wire SPI interface and 4-20 mA
output. Also requires an external depletion mode FET (DN25D, ND2020L,
ND2410L, etc) for its power supply section.
It can be loop powered if you want to use opto-isolators on the 3 control
lines. That's how we use it for one of our RTD temperature monitoring systems.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 20 years of Engineering Innovation (1984 - 2004)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
Sent: Wednesday, June 30, 2004 11:51 AM
> Richard,
> or
> $10)
> /Henrik Olsson
> From: "Richard" <rwskinner@a...>
Stamp?
> you
> > Thanks,
> > Richard
> Yahoo! Groups Links
> [noparse][[/noparse]Scanned by AwesomeNet Anti-Virus]
