EEPROM space, can be used as a variable?
Hello.
If I reserve EEPROM space at compile time, is there a way to use it
as a variable, for instance can I SERIN a string of text to an array
in EEPROM space? Is this possible?
What about scratchpad ram? Or is that ONLY usable via PUT and GET?
Ryan
Ryan
with SERIN, then WRITE to put it into EEPROM. You can buffer a SERIN
stream to Scratchpad (because its RAM and fast; EEPROM is slow). Like
this:
SERIN pin, baud, [noparse][[/noparse]SPSTR \12]
This will capture 12 bytes from the serial stream and stuff them into
the Scratchpad. Note that this feature is only available on the BS2p
and BS2pe. You can then use GET to retrieve bytes from the Scratchpad.
-- Jon Williams
-- Dallas Office
From: LostboY [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sdJvqrGslyA5PzYjPREaEuX-AvJkcCKR1K5LVWIn7MRr_rvLO7bGdUGPVQWpk4ff7Ke-SXB_8ztJdtYKRA]hangook21@y...[/url
Sent: Wednesday, June 30, 2004 12:52 AM
Subject: [noparse][[/noparse]basicstamps] EEPROM space, can be used as a variable?
Hello.
Ryan
recommend, use the Help file as it is easier to distribute so it
contains the latest information.
Yes, SPSTR always starts writing at location 0, and its only limitation
is number of bytes; it does not look for a terminating character.
-- Jon Williams
-- Dallas Office
From: LostboY [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=k3pCi0hCfHk2E4r9Qqw7Y1FSA51yvpmuAP3FhFY3CtqmhJuQion--Hzrui5DQdao6bnyJzvgQtsZMg]hangook21@y...[/url
Sent: Friday, July 02, 2004 12:51 AM
Subject: [noparse][[/noparse]basicstamps] Re: EEPROM space, can be used as a variable?
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> No, you cannot SERIN directly to EEPROM. You need to use a RAM
variable
SERIN
Like
> this:
into
> the Scratchpad. > -- Jon Williams
Thanks for the answer. Can I set a certain character to terminate,
like this:
SERIN pin, baud, [noparse][[/noparse]SPSTR \12 \$AA]
Also, I assume that SPSTR is "scratch pad string" yet I cannot find
this instruction anywhere in the Basic Stamp Manual. Is there
anywhere this instruction is documented, or is this just a variable
name that you have assigned, if so, how do I allocate a 'scratch pad'
variable? I was under the impression that the only way to access the
scratch pad ram was with the "get" and "put" set of instructions.
Also, with the above command, will it aways begin putting the ASCII
at location scratch pad 0? (ie can I tread scratch pad ram as a big
array?)
Thanks again,
Ryan
