IR PhotoTransistor
I need to find what RL should be used on a Radio Shack PhotoTransistor (NOT
THE DECODER, JUST THE PhotoTransistor that comes packaged with a LED)
This could be either as a Common Cathode or Common Anode setup to use this
as a switch. If connected to P3, for instance, I would have a 1 or 0 if the
LED was passing to the PhotoTransistor or just the opposite if it were
blocked.
Barry
blocked.
Barry
and higher sensitivity, use 100K. Instead of Radio Shack, you can also
use Phlmore platic fiber optic photologic detectors, without the plastic
light pipe. They are TTL/CMOS compatible.
Dennis
From: Barry Erick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=aLJUyvtxEX_psyohKmBFQ5EzlwKa2ZLkZd9BIw96P_uq5RlfwK-WNzY7CIaxichSd7Pm5Hk]berick@e...[/url
Sent: Tuesday, June 29, 2004 7:05 PM
Subject: [noparse][[/noparse]basicstamps] IR PhotoTransistor
(NOT THE DECODER, JUST THE PhotoTransistor that comes packaged with a
LED)
this as a switch. If connected to P3, for instance, I would have a 1 or
0 if the LED was passing to the PhotoTransistor or just the opposite if
it were blocked.
Barry
Yahoo! Groups Links
sent the message last night and when it did not show, I thought maybe it was
because I did not post it from Yahoo and just my email. So I posted again.
Then I saw the first message was just stuck in my outgoing mail and was
never sent until it was too late.
It turns out my 60 year old eyes misread the resistor I was using and I
picked a 1.2k instead of a 12k. That fried the phototransistor and my 60
year old mind also skipped over good old ohms law on the value. Maybe
because I am on vacation and not doing my main work that I have over 40
years in that uses ohms law daily.
Barry
> From: Dennis O'Leary [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=43epQmD9j0qjps5mM9u7DTlSp9ahtBDb4nNkMPoICF30SbkxoiTl-2IVsgz4G6xrlYngCRhQf6oCKVv_EQ]doleary@e...[/url
> Sent: Wednesday, June 30, 2004 2:06 PM
> Subject: RE: [noparse][[/noparse]basicstamps] IR PhotoTransistor
> For faster response and lower sensitivity, use 10K. For slower response
> Dennis
> From: Barry Erick [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=i76-l4KH0JMe2U5rGSFSyr9JesCiVpfBP55F0VNA2HNwL2ATBffj8K6KXaXqq0wSh44QgRmC]berick@e...[/url
> LED)
> it were blocked.
> Barry
> Yahoo! Groups Links
> Yahoo! Groups Links
