serin?
I have built and tested the serin & serout example in the help file.
Every thing check out. I tested my other device and it work like it
suppose to. However when i put the two together, they're not talking
correctly.
example: if i send out "A" which is the ascii 65. The Bs2p24
recieves (DEC) 252 or the "u" with 2 little dot above it
If i send "0" out, the stamp reads (Dec)0 or clear the debug screen
if not dec?
Thanks for any help offered.
tony
correctly.
if not dec?
tony
usually the culprit.
-- Jon Williams
-- Dallas Office
From: dakota_99_64804 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=v6KDxWStjNVn4J7PDLcf-JwXb-YeuMx57bd6cNfUrW7V88Jit4fl11o-eRE2g0xB1JgnZOI8W9rml6-jRvQdmQ]dakota_99_64804@y...[/url
Sent: Monday, June 28, 2004 4:27 PM
Subject: [noparse][[/noparse]basicstamps] serin?
correctly.
if not dec?
tony
the templete file and saw it should be 240 for bs2p.
thanks again,
Tony
--- Jon Williams <jwilliams@p...> wrote:
> Are you sure you have the baudmode parameters
> correct? -- this is
> -- Jon Williams
> -- Dallas Office
> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tgkmGh1hRqskpmIBp7tx0uZUfgr3IXQ6ErJLNSybcJBySMXPUsglcyjMCRtTYOO2TR9J65MG4KMS1YfvigtSqg4]dakota_99_64804@y...[/url
> in the help file.
> it work like it
> they're not talking
> correctly.
> The Bs2p24
> above it
> the debug screen
> if not dec?
> tony
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
> Yahoo! Groups Links
__________________________________
Do you Yahoo!?
New and Improved Yahoo! Mail - Send 10MB messages!
http://promotions.yahoo.com/new_mail
template includes the following section:
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T1200 CON 813
T2400 CON 396
T4800 CON 188
T9600 CON 84
T19K2 CON 32
T38K4 CON 6
#CASE BS2SX, BS2P
T1200 CON 2063
T2400 CON 1021
T4800 CON 500
T9600 CON 240
T19K2 CON 110
T38K4 CON 45
#ENDSELECT
Inverted CON $4000
Open CON $8000
Baud CON T9600
A while back I uploaded a ZIP containing several files with useful
conditional-compilation constructs to make moving from one BASIC Stamp
module to another a bit easier. The file is called:
Conditional_Compilation_Examples.ZIP
-- of course, you will find it in the Files section.
http://groups.yahoo.com/group/basicstamps/files/
-- Jon Williams
-- Dallas Office
From: not today [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8UqKJhI0a5r9PtDKNEJDI7OBsVEPFH8Fsso1AwPSH-Oko3QoE4EipepuAULp_FDgFHtG4m6R5GoV79SURSMhkZRmDd0]dakota_99_64804@y...[/url
Sent: Monday, June 28, 2004 7:59 PM
Subject: RE: [noparse][[/noparse]basicstamps] serin?
Cool that was it... I had 16468 in, but referred to
thanks again,
Tony
> correct? -- this is
> -- Jon Williams
> -- Dallas Office
> in the help file.
> it work like it
> they're not talking
> correctly.
> The Bs2p24
> above it
> the debug screen
> if not dec?
> tony
