"No Basic Stamps found" error
Hello all.
I am a novice to the stamp module.
I am trying to program a BS2.
I have setup the serial connector found on the bs2 datasheet. When I
connect it and power up the module with about 9.1 vdc, I get com1
verification with loopback-yes and echo-yes.
I am running 2.1 beta 1 software.
When I run the program, the following error appears and the program
halts: "No BASIC Stamps found"
I have verified pin connections 1-4 on the stamp and they are set
correctly.
I also noticed I am not allowed to debug any pins...
Any assistance would be greatly appreciated! Thank you...
correctly.
> Hello all.
I
> correctly.
I too am having the exact same problem with my BS2. I just
contacted Parallax and they went through several tests with me.
Nothing seemed to fix the problem so they stated that I probably have
a bad stamp and requested that I send it back to them for testing. In
the event that they find the stamp to be bad they said they would
send me another one free of charge. Sorry I don't have any solutions
for you to the problem. If you figure something out I would be very
happy to hear about it.
disabled. Some Toshiba Laptops definitely have this problem.
2. You also need pin 6 and 7, as they connect to a looped back
connection on the board so the IDE can detect a connected
cable. If you got 'loopback OK', then you already have this.
--- In basicstamps@yahoogroups.com, "swammie812000" <swammie81@a...>
wrote:
> --- In basicstamps@yahoogroups.com, "casadepoli" <poli@p...> wrote:
> > Hello all.
When
> I
program
> > correctly.
have
In
solutions
Have you monitored the volatage supply to the stamp when you try to program?
When I say voltage to the stamp......literally on the stamp, not coming out
of your power supply, not just before the stamp, but ON the stamp.
A scope is best. Confirm the voltage does not drop when you go to program.
Ken
Cas,
Are you using a Toshiba laptop? They need to have the FIFO buffers turned of
in the hardware manager.
Jonathan
www.madlabs.info
Jonathan
www.madlabs.info
Sent: Monday, June 28, 2004 8:13 AM
Subject: [noparse][[/noparse]basicstamps] "No Basic Stamps found" error
> Hello all.
> correctly.
> Yahoo! Groups Links
the PC case.
Try to reconnect it again.
>From: "casadepoli" <poli@p...>
>Reply-To: basicstamps@yahoogroups.com
>Date: Mon, 28 Jun 2004 15:13:34 -0000
>Hello all.
>correctly.
>Yahoo! Groups Links
_________________________________________________________________
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
