Eb500, BS2 and a nokia 6600
Hi all,
I have recently connected an eb500 to a bs2 to connect it with a
nokia 6600 bluetooth enabled mobile phone. The list command finds the
nokia 6600 no problem, using the address found I issue the connect
command to the eb500 from the bs2, the phone responds with a dialog
box asking for a passcode to authenticate the connection! Does
anybody know what the authentication code is for the eb500? I get the
same result if I try to pair the phone with the eb500 & also I have
tried to connect the eb500 with a usb bluetooth adapter connected to
a pc which also asks for an authentication code. Any ideas? I have
asked parallax for help who refered me to e7eng but sadly to date
after a number of e-mails a7eng have not responded. Any help would be
much appreciated.
Tom.
much appreciated.
Tom.
Just a shot in the dark!
Sent: Saturday, June 26, 2004 5:30 PM
Subject: [noparse][[/noparse]basicstamps] Eb500, BS2 and a nokia 6600
> Hi all,
> much appreciated.
> Tom.
> Yahoo! Groups Links
properties dialogue box for the Bluetooth connection on your pc there
usually is a check box named "Secure Connection", and the default is 'yes',
so you have to change that to 'no'.
________
> Hi all,
> much appreciated.
> Tom.
> Yahoo! Groups Links
if you put the same code in your cell and the same in your bs2 it will work.Like if you put the number 1 in the cell you must put number 1 in bs2. Only same number can do the connection.
But if you read the manual of nokia you can put your bs2 as a trusted source.like if your bs2 is trusted from your cell it will never ask you for a code and the connection is always open.So you must read Nokia's manual and read how to make advises as trusted.
Thats all.
Do You Yahoo!?
