Debug and LCD — Parallax Forums
Debug and LCD
edited 2004-06-25 17:59 in General Discussion
Hello Stampers,
Just a taught......
I frequently use the BPP-420 4x20 Serial LCD module (Scott Edwards) in
combination with the basic stamps.
Wat I want to do is to use an LCD module as a debug output screen, connected
on the dedicated "program-debug" port 16 .
I 'll to put several debug statements in the program, and if the LCD module
is connected it must display the debug output strings, when the LCD isn't
connected, the program simpy runs blind.
I think this will be helpfull for "in the field" problem solving.
Has anybody already done this, or can sombody give me a few hints..........
Thanks in Advance
Met vriendelijke groetjes,
Michel De Meester
Biotechnisch Onderhoud
Universitair Ziekenhuis Antwerpen
Wilrijkstraat 10
2650 Edegem - B
tel: ++32 (0)3 821 36 47
e-mail: michel.de.meester@u...
    edited 2004-06-25 15:16
    yes, you can do something like this.
    You shouldn't use the 'DEBUG' statement, though,
    as it is NOT included in code compiled for 'running'.
    You should use:
    SEROUT 16, 16384 + 84, "Debug Statement", 13
    This does exactly what a DEBUG statement does,
    except it is included in running code.
    Oh, and the '16' above indicates to use the
    'programming port'. You can actually use ANY
    I/O pin 0 through 15. If you get a 'serial
    back-pack' for your LCD, you are good to go.
    If you MUST use the physical pin 1 and 2 on
    the module (the programming port) you should
    be aware that these pins implement a pseudo
    max232 circuit, which modulates the -12 volts from
    the PC TX line to make a good RX-Out signal.
    You may have to do something to get this to
    work -- like connecting -12 to the TX pin.
    Now all you need is a
    --- In basicstamps@yahoogroups.com, "De Meester, Michel"
    <Michel.De.Meester@u...> wrote:
    > Hello Stampers,
    > Just a taught......
    in
    connected
    LCD module
    isn't
    hints..........
    > Thanks in Advance
    > Michel De Meester
    > Wilrijkstraat 10
    > 2650 Edegem - B
    edited 2004-06-25 15:47
    DEBUG is indeed compiled into the code -- it's basically as shortcut to
    SEROUT with slightly different formatting (and devoted to pin 16 at 9600
    baud). I routinely create programs that use DEBUG and ultimately end up
    communicating with a generic terminal program. With PBASIC 2.5 you can
    also use DEBUGIN (a simplified version of SERIN on pin 16 at 9600 baud)
    to get information from a terminal.
    -- Jon Williams
    -- Dallas Office
    From: Allan Lane [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=MHd1OZ66awlzW6m_cqSjhveP6WsjTwhfn6AoAvbBFiq_EmqPX5PYySfb8cqVwmQ7AHgxz9bV09gKpSSe6lu_QbgIpQ]allan.lane@h...[/url
    Sent: Friday, June 25, 2004 9:16 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Debug and LCD
    You should use:
    > Hello Stampers,
    > Just a taught......
    in
    connected
    LCD module
    isn't
    hints..........
    > Thanks in Advance
    > Michel De Meester
    > Wilrijkstraat 10
    > 2650 Edegem - B
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    Cool. Lesson learned.
    --- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
    shortcut to
    9600
    end up
    can
    baud)
    > -- Jon Williams
    > -- Dallas Office
    > From: Allan Lane [noparse][[/noparse]mailto:allan.lane@h...]
    > You should use:
    > > Hello Stampers,
    > > Just a taught......
    Edwards)
    > in
    > connected
    > LCD module
    LCD
    > isn't
    > hints..........
    > > Thanks in Advance
    > > Michel De Meester
    > > Wilrijkstraat 10
    > > 2650 Edegem - B
    Subject
    > Yahoo! Groups Links
    > abuse@p...
