ac light dimmer 2.0, now with x10
hi, last week I asked about making a dimmer with a stamp, and some ppl
on the list suggested I try an x10 device, which I did. Fun and easy.
However, what I really want to do is have a light slowly fade on. Using
the supported x10 commands listed in the bs2 docs, I was able to fade a
light on using the bright command, but only if the light had been dimmed
out first. Any advice?
thanks,
Mark
thanks,
Mark
ppl
easy.
Using
fade a
dimmed
> thanks,
> Mark
Mark, when you are working with the x10, and you are doing dimming,
you have to dim it to dark to "turn off" and brighten to where you
want it to "turn on". The x10 goes to full on when you turn it off
completely and then give the on command. I had that same prolem
using computer control.
Regards
Chet
it's not possible to have a circuit that does the following >
off > slowly brighten from off to on > off > slowly brighten from off
to on> repeat
>>thanks,
>>Mark
>Regards
>Chet
>from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
>Yahoo! Groups Links
'dim' to 0% on. If you actually use the
'off' command, the next 'on' OR any 'DIM'
command will turn the light on full-bright.
So, just never turn the light "off", instead
dim it to zero, then dim it up from zero
to get more light. This works fine.
> Hi Chet, I found the same thing you are describing. Are you saying
that
off
> to on> repeat
some ppl
easy.
Using
fade a
dimmed
> >>thanks,
> >>Mark
dimming,
off
> >Regards
> >Chet
> >Yahoo! Groups Links
wrote:
> With X10, you can do this, but only if you
This is typical of lights and motors. without some pretty good
circuits, you need to get the light to turn ON with a signifigant
amount of power. The filiment will act like a resistor and begin to
heat, then illuminate.
If you used a DC voltage to the lamp, you would lose some of the
brightness, but gain a lot of control.
for your Triac, look into a triac driver. I have been reading about
them and it seems you can get a triac driver that is an
optoisolator. it handles the zero corssing by activating the triac n
the first or second quadrante and therefor it only tries to control
the triac in the positive section of the sinewave.
Dave
"dim" anything. They're only useful for turning on big loads like contactor
coils. Their reason for existing is that they'll only ever start conducting
during the off-time of the sine wave, they won't cause any RF hash from the
big current that is drawn if a triac turns on while the AC is close to 170
volts... (yes, 120 RMS is close to 170 volts peak or 340 volts P to P). All
Triacs (and SCR's) wait for the voltage to return to near zero before they
unlatch, as it were. So they're all zero crossover on release.
Light dimmers work by turning "on" while the 120 Volt AC voltage is in the
middle of the cycle somewhere. In fact at 50% dimming, the triac is turning
on exactly at the peak voltage of the sine wave. That's why you can hear
light bulb filaments "sing" while dimming. It's the quick rise time of the
Triac that can make the filaments shake. High quality dimmers use a big
series inductor feeding the light bulbs which dramatically slows down that
rise time (flywheel effect) and limits the RF hash generated.
You can, if fact, rectify the 120 Volt RMS line voltage to about 170 Volts
DC, and then chop it rapidly with a big Mosfet using PWM without any of
the line-sync issues of Triac control. Of course, a 120 Volt light bulb is
at 100% power with 120 Volts, either RMS or DC, so you'll never be able to
apply 100% duty cycle 170 volt DC to one, or bad things will happen. Think
bright lights and a really quick burn out. (been there, done that).
I learned all this the hard way some 25 years ago when I built really big
light-dimmers for my rock band. Our main lighting rig had fifty 1KW PAR
lights with separate dimmers for each lamp. It really cooked. The real fun
was the strobe I built from a surplus airport landing strobe rated at 2,000
watt-seconds. We used a microwave transformer to power it up and an ignition
coil from a car to trigger it. When it fired it would completely overwhelm
the 50,000 watts of lighting we already had on stage, and we had to be very
careful not to look directly at the bulb. I did that once and was seeing big
purple flashes for the next few hours.
But I digress.....
Mike Sokol
mike@f...
www.fitsandstarts.com
" One should not increase, beyond what is necessary,
the number of entities required to explain anything"...
-William of Occam-
Sent: Thursday, June 24, 2004 6:25 PM
Subject: [noparse][[/noparse]basicstamps] Re: ac light dimmer 2.0, now with x10
> --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
> Dave
> Yahoo! Groups Links
> Just to expand a bit on zero-crossover triacs, they'll NEVER be
able to
contactor
conducting
from the
to 170
P). All
Interesting point here.
AC voltage times 1.414 would offer the peak voltage so if you are
thinking 120VAC RMS, it is really 170 peak or 340 P to P. and if
your mains fluxuate, considder 130VAC within utility compnay limits.
so 185V peak is not out of the question.
Also, considder that rectified AC with a filter can offer these
voltages in DC so the simple "convert to DC and dim" approach is not
totally simple.
A voltage monitoring/clipping circuit would be in order.
Dave
if you wish). The trick is not to switch the unit off. The "off"
is actualy fully dimmed.
Have ben using that for year now.
Good luck
Chet
that
off
> to on> repeat
some ppl
easy.
on. Using
fade a
been dimmed
> >>thanks,
> >>Mark
dimming,
you
off
> >Regards
> >Chet
> >Yahoo! Groups Links
