Monitoring Without Resetting
In a message dated 6/23/2004 1:46:09 PM Eastern Daylight Time,
tboonefisher@s... writes:
> I have a BS2p24. I want to monitor the serial
> DEBUG output without any possibility of resetting
> the Stamp. Can I accomplish this by simply leaving
> the ATN pin(3) open?
You would also have to disconnect the Reset button.
Sid
Sid
Tom Fisher
Dallas,TX
should achieve this. It IS the module pin 3,
so if you leave pin 3 open, you can't reset
the module.
From schematics, it looks like there is no
on-card pull-up for this, so either there is
a pull-up on the module itself, or you don't
need one.
Therefore, this should work.
--- In basicstamps@yahoogroups.com, "TBooneFisher"
> Thanks,
> Tom Fisher
> Dallas,TX
