What''s a microcontroller ?
I think what they want is the data to control your servo not displayed.
Press start to activate is OK, its not data.
Coincendently, you made me go back and do this problem with your email.
Originally I skipped it, but Im glad Ive done it now. Learned somethin!
Thank you.
Sincerely,
Shawn Lowe
> [noparse][[/noparse]Original Message]
> From: jack <mrripple@s...>
> To: <basicstamps@yahoogroups.com>
> Date: 6/21/2004 9:28:35 PM
> Subject: Re: [noparse][[/noparse]basicstamps] What's a microcontroller ?
> Ok i understand all of that coding . but when i push the P3 button i still
> have data showing up in the debug terminal and after that "Press Switch
to
> start machinery" comes up as long as the button P3 is pressed. The Led is
> red as they want in the problem . I just can't figure out how to stop
data
> from going to the Debug Terminal when P3 is being pressed.
> From: <Newzed@a...>
> Sent: Monday, June 21, 2004 9:33 AM
> > In a message dated 6/21/2004 10:10:21 AM Eastern Daylight Time,
> > mrripple@s... writes:
> > > The first problem on page 132 below the word Projects. number one.
Can'
> > > figure out how to stop the terminal from accepting data when P3 is
> pressed.
> > You want to modify the program so that it stops accepyting commands.
> > Clues:
> > P3 = in3
> > p4 = in4
> > if P3 is pushed then in3 = 1
> > if P4 is pushed then in4 = 1
> > You will need a new label at the start of the program:
> > start:
> > if ...........? then.............?
> > Is tht enough help or do you need more?
> > Sid
> > [noparse][[/noparse]Non-text portions of this message have been removed]
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject
and
> Body of the message will be ignored.
> > Yahoo! Groups Links
> Yahoo! Groups Links
Thank you.
Sincerely,
Shawn Lowe
to
data
> From: <Newzed@a...>
Can'
> pressed.
> > Clues:
> > P3 = in3
> > p4 = in4
> > start:
> > Sid
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
