Read, Write and send data
I am able to read/write data and display it on the screen. The hard
part is trying to take that data and be able to use it. I storing
different values using the write command like this:
write 0,124
write 1,342
write 2,221
write 3,230
Now, how do I assign these values commands. In other words I want
to say something like "If write 0=124 then startprogram". This
isn't working and I am hoping someone has dealt with this before.
Also, is there a command to clear all of the eeprom data I created?
Thanks in advance,
Chris
write 0,124
write 1,342
write 2,221
write 3,230
Thanks in advance,
Chris
>Hi,
>write 0,124
>write 1,342
>write 2,221
>write 3,230
Chris -
Placing data INTO EEPROM is done with WRITE as you have done above.
Retrieving data FROM EEPROM is done with READ. When you retrieve data from EEPROM you READ it into a VARIABLE. Check the manual for details, but
a simple example is shown below:
WRITE 0,124 'Place one byte of data in EEPROM location 0
READ 0,Item 'Retrieve one byte of data from data location 0
> This
No, you would have to do that manually. Remember there are just a finite number of WRITES that can be done to a EEPROM location before it wears out. See the manual for additional details.
>Thanks in advance,
>Chris
Bruce Bates
Larry Gaminde
Sent: Friday, June 18, 2004 11:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] Read, Write and send data
> At 06:20 AM 6/19/04 +0000, christopher41877 wrote:
> >Hi,
> >write 0,124
> >write 1,342
> >write 2,221
> >write 3,230
> Chris -
> > This
> >Thanks in advance,
> >Chris
> Regards,
> Bruce Bates
> Yahoo! Groups Links
342 at the end of that sequence, it holds 86 -- the reason is that WRITE
works with bytes and 342 is greater than what a byte can hold.
Fix your code like this:
WRITE 0, Word 124
WRITE 2, Word 342
WRITE 4, Word 221
WRITE 6, Word 230
By using the Word modifier, two bytes are used for storage, making room
for changes that I assume will come.
On your quest to "assign values to these commands", here's what I think
you need to do:
Get_Command:
READ Location, Word command
SELECT command
CASE 124
' do something
CASE 342
' do something
ENDSELECT
-- Jon Williams
-- Dallas Office
From: christopher41877 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wwYQwszmp_jezu7gVzS09qKf8ax0teUxLZDyJD7CUABxN0VcBQSq9fFazVoCQ8F16yN7Gjkj06E6x2AapzYP4yQtvS7RhQ]CHRIS@R...[/url
Sent: Saturday, June 19, 2004 1:20 AM
Subject: [noparse][[/noparse]basicstamps] Read, Write and send data
write 0,124
write 1,342
write 2,221
write 3,230
Thanks in advance,
Chris
