How Much Current Can A BS2p24 Sink??
In a message dated 6/18/2004 7:57:19 PM Eastern Daylight Time,
tboonefisher@s... writes:
> I need to use a BS2P24 output to switch
> an LED that is connected to a +12.5V(up to 15V)
> supply via a 1.5Kohm series resistor. The stamp will pull
> the line low to light the LED. I figure the stamp will need
> to sink at least 8.7ma to do this. Is this a problem or do
> I need to add more series resistance or a buffer device?
> TIA,
You could saute your BS2P. Use a transistor to turn the LED one or off.
Sid
> TIA,
Sid
TIA,
Tom Fisher
Dallas,TX
Even though the current might be within limits, the voltage isn't. When the
LED is off, the Stamp pin will "feel" the full supply voltage, and anything
over 5V is a major no-no.
You can use an inexpensive NPN transistor such as a 2N3904, PN2222, or
2N4001. At the current level you are controlling, a 4.7k ohm resistor would
supply plenty of base current to the switching transistor. Connect the
transistor's emitter to ground, the collector to your load, and connect the
4.7k resistor between the Stamp's I/O pin and the transistor's base. The
other side of the load is connected to B+. Anything from 1k to 10k ohm
should work fine for the base resistance if you don't have a 4.7k handy.
The first schematic at
http://www.glitchbuster.com/pwrswtch.htm
sort of shows it. Take a look at how R1 and Q1 are connected. (Eliminate
the pushbutton switch, R2, and Q2). Your LED/series resistor would be
connected between B+ and the "top" (collector) of Q1.
Hope that helps,
-Randy
> TIA,
> Tom Fisher
> Dallas,TX
