Need help with writing to EEPROM
Archiver
I have a BS2 and the program I am trying to make isn't working. I
knwo there is a way to do it but my knowledge of PBASIC isn't that
vast and I was hoping someone could point me in the right
direction. What I am trying to do it to take a numerical value
(ASCII, Binary, Decimal...) and store it temporarily in the stamp.
When 4 numbers are received I need to recall all of them and send
them at the same time to an output pin on the stamp. I know how to
write numbers using the write command but how can I write a value
like an analog value from an input pin? Also, when I want to recall
that number, what command do I use to do this?
Thanks in advance for any help,
Chris
Chris
Can you be more specific? What are your inputs (are you using an A2D?)?
What are your outputs? Displays? LEDs? Do you want an analog output?
-- Jon Williams
-- Dallas Office
From: christopher41877 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=9QKNUFAOOO3d26HNmT_KgvBsrF7zI0PkhQ3O9IAT5YQYKEoSMlNQbJ1Zu0XHhoup8TdHm1NO-OJi3pm0fYS6ooOwvqGl]CHRIS@R...[/url
Sent: Friday, June 18, 2004 9:25 AM
Subject: [noparse][[/noparse]basicstamps] Need help with writing to EEPROM
Chris
You can Write a Byte to a specified location in EEPROM and then Read it back
to RAM, again specifying its location.
So, 'Write' and 'Read' are the keywords, you can find the specific use of
them in the (online) Help function.
Klaus
Sent: Friday, June 18, 2004 4:24 PM
> Hi,
> Chris
> Yahoo! Groups Links
wrote:
> Hi,
recall
> Chris
Hi Chris,
Seems like you put a whole lot into the post.
To bring in any value, it is either a 1 or 0 that would be the state
of the pin.
If you start with things like POT or RCtime, you can get more than a
bit, you can get a byte or a word.
Once you decide HOW you bring in your data, it is stored in a
variable that you use for that command.
Read a little on RCtime to get the idea.
Also, you mentioned the word "analog" This may be a simple RCtim
sort of input that offers a kinda-sorta analog input or it could be
from an analog to Digital converter ADC chip which is external and
uses a serial connection.
But, for you to read the port, you have to have a variable set aside
for it and your reading will be stored until you read a new reading
or lose power.
Dave
then sending it to the stamp. I believe the output from the
hardware is ASCII but I don't have it yet. So, the stamp receives
one ASCII number and stores it, the does it three more times for a
total of four. Once the four numbers are received it will go back
to the memory and recall the numbers, like a 4 digit pin. Now, it
has the numbers and then I will assign a DTMFOUT command to the
number. I would like to use "if then" statements because they are
easy. If there is another way I can do this or an easier way I
would appreciate any comments.
Chris
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Chris,
A2D?)?
output?
> -- Jon Williams
> -- Dallas Office
> From: christopher41877 [noparse][[/noparse]mailto:CHRIS@R...]
> Hi,
stamp.
to
recall
> Chris
you need to figure out, of course, is what your incoming DTMF values are
going to be. If you get lucky, they will be decimal values that
correspond to the telephone keypad. If that's the case, you can use an
array of nibbles.
This is off the top of my head -- use for guidance only.
key VAR Nib(4)
idx VAR Nib
Main:
GOSUB Get_Keys
' do something else
FOR idx = 0 to 3
' output slowly on P0
DTMFOUT 0, 500, 100, [noparse][[/noparse]key(idx)]
NEXT
END
Get_Keys:
idx = 0
FOR idx = 0 TO 3
' wait for key from hardware -- assign value to key(idx)
NEXT
RETURN
From: christopher41877 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=BYL2X5THYC8dBZv4aMlS-7MqIMIlNo2mlBCgTV1HuB0EZKlqbRcprmGGMU_j5yRr4hIztqZSImWy2XJWOdWxVWtr]CHRIS@R...[/url
Sent: Friday, June 18, 2004 10:44 AM
Subject: [noparse][[/noparse]basicstamps] Re: Need help with writing to EEPROM
I am taking DTMF tones in, converting it with external hardware, and
Chris
wrote:
> Chris,
A2D?)?
output?
> -- Jon Williams
> -- Dallas Office
> Hi,
stamp.
to
recall
> Chris
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
