Opto Results & LED Quiz
Any way, the optos came in today and installed it on the breadboard and my
schematic worked fine.
The voltage coming out of the opto is only 4.35 volts so I lowered the
value of the LED resistor to 250 ohms in order to get the 10 ma thru it. It
calculates out at 17ma but was only 10ma when I checked it. I'm sure I'm
missing some calculation somewhere.
Sorry if this stupid, but I'm trying to learn. Everything I've done in the
past with LED's was using default values copied out of the project books.
How is the best way to determine how much current to put thru an LED for the
best results. Example: The Opto's LED states Forward Voltage of 1.25 volts
typical, I_F = 50ma
Is the I_F mean forward current? Does that mean that is the Max Current I
can use on that LED "or" the amount I "should" use?
So if I see a LED rated like this: vi @ if (ma) = 1.9 @ 20 means that 20
ma is where is should run and there is a 1.9 volt drop across it?
Richard
Sent: Thursday, June 17, 2004 5:08 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Quick Opto-Coupler Question
> Whoa, the timing on the messages on the list is kind of messed up.
> Reason for using the Opto, because I wanted to be safe in using the 24
> volts. I also looked at the Stamp PLC and it had a very simular circuit
so
> I thought it was the way to go.
> I guess there is a dozen ways to skin a cat.
> From: "Dave Mucha" <davemucha@j...>
> Sent: Thursday, June 17, 2004 10:17 AM
> Subject: [noparse][[/noparse]basicstamps] Re: Quick Opto-Coupler Question
> > --- In basicstamps@yahoogroups.com, "Richard Skinner"
> > <rwskinner@a...> wrote:
> > > I revised it some: I didn't like the way the LED Indicator was so I
> > > Grounded the LED then went from the LED thru a 470 ohm resistor to
> > Pin 4 of
> > > the opto. That way when the opto goes high it lights the LED.
> > I'm not sure why you are using an isolator ?
> > you have the two circuits connected together.
> > Why not eleminate it and just use a voltage divider
> > with a 10k ohm to the Stamp input ?
> > If you need more power, or want the LED on the Stamp side, you can
> > substitute a npn transistor.
> > If you want isolation, disconnect the common ground line and the
> > resistor in it. If you can share the common ground, then the
> > circuits are not isolated and you don't need the isolator.
> > Dave
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed. Text in the Subject
and
> Body of the message will be ignored.
> > Yahoo! Groups Links
> > [noparse][[/noparse]Scanned by AwesomeNet Anti-Virus]
> Yahoo! Groups Links
typical, I_F = 50ma
Richard
so
> > Pin 4 of
> > Dave
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
www.theledlight.com/technical.html
Sent: Thursday, June 17, 2004 9:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] Opto Results & LED Quiz
It
the
the
volts
> typical, I_F = 50ma
> Richard
> From: "Richard Skinner" <rwskinner@a...>
> so
> > > Pin 4 of
> > > Dave
> and
> > > Yahoo! Groups Links
and
> > Yahoo! Groups Links
> Yahoo! Groups Links
10 mA to 15 mA. 20 mA can be used, but you
don't get much more light between 15 and 20 mA.
The 1.25 volts at 50 ma is trying to show the
max voltage the LED drops -- you wouldn't want
to run it at 50 mA.
And, you can 'pulse' LED's at high current
(50 mA? 100 mA?) for SHORT periods of time
to get greater brightness. However, if your
code that pulses the LED's breaks, you burn
them out.
To calculate LED's you need a few values.
1. What is the constant voltage drop acrosss it,
when it is 'on' -- lit.
Typically 1.2 to 1.4 volts.
2. What is the typical current to run it at.
Many specs tell you the MAX current you COULD run
it at -- usually you don't want to design to this,
since if you go over EVEN A LITTLE you burn out the
LED.
3. What is the MINIMUM current to run through
it before it lights at all. Few specs tell you
this, you may have to experiment.
There is some range of current that the LED lights
fully. Above this it burns out. Below this it
looks dim. You want to be in the middle to lower
end of this range. The voltage drop across the LED
is constant the whole time at around 1.4 volts.
and my
lowered the
thru it. It
sure I'm
done in the
books.
LED for the
1.25 volts
> typical, I_F = 50ma
Current I
that 20
> Richard
the 24
circuit
> so
was so I
resistor to
> > > Pin 4 of
can
> > > Dave
Subject
> and
> > > Yahoo! Groups Links
Subject and
> > Yahoo! Groups Links
> them out.
<HUGE snip>
You can pulse an LED with 100mA as long as the duty cycle does not
exceed the max for the device. so a 50% duty cycle would deliver
50mA.
But, the LED will be signifigantly brighter at the higher currents
and that makes it worth the effort.
also, you can pulse them at a higher current, for shorter times and
use less power for a brighter light.
Dave
I have a green LED which states: 2.3 @ 20 Vf @ If (ma)
The voltage into my Darlington is 5.3 volts and the output out of my
Darlington is 4.35 volts
I'm going to use 15 ma to be safe.....
4.35 - 2.3 = 2.05 / 15ma = 136 ohms. Well, I actually have 150 ohms in my
box.
2.05 / 150 = 13 ma so a 150 ohm 1/8 watt would be fine.
On the OptoCoupler, its ratings are If = 50ma Typical Vf = 1.25
My input voltage is 24 vdc nominal (18-28). Design for 1/2 the ma @ 25 ma.
24 vdc - 1.25 = 22.75 volts / 25ma = 910 ohms so in my drawer I have a 1K
18 volts - 1.25 = 16.75 / 1000 = 17ma
28 volts - 1.25 = 26.75 / 1000 = 27 ma
24 volts - 1.25 = 22.75 / 1000 = 23 ma
So, I take it a 1K resistor from 24 volts to power my Opto's LED (4N32)
would work perfect, if 25 ma is good for long life. Whoa, that calculates
0.600 watts so it needs a 1 watt resistor????
Have I figured it out "Finally"?
Richard
Sent: Friday, June 18, 2004 10:29 AM
Subject: [noparse][[/noparse]basicstamps] Re: Opto Results & LED Quiz
> > them out.
> <HUGE snip>
> 50mA.
> Dave
> Yahoo! Groups Links
@ 25 ma.
have a 1K
(4N32)
calculates
> Richard
eeeeep ! do not pass, GO, do not collect $200.00.
the opto is rated for 20mA, not 50 or 60. check where that value
comes from and what the graphs show as typical use.
The opto you listed has a spec from Fairchild that lists the largest
tranfer at something between 2 and 3 mA, with signifigant ratios down
to about 0.7mA
The 60mA to which you speak seems to me to be the collector/emitter
and not the base.
Dave
better. Also allows me to use allot lower wattage resister!
Were my other LED calcs okay then?
Sent: Friday, June 18, 2004 3:12 PM
> @ 25 ma.
> have a 1K
> (4N32)
> calculates
> > Richard
> to about 0.7mA
> and not the base.
> Dave
> Yahoo! Groups Links
