Parallax 4X4 matrix keypad — Parallax Forums
edited 2004-06-18 20:18 in General Discussion
In a message dated 6/17/2004 2:59:06 PM Eastern Daylight Time,
CHRIS@R... writes:
> Has anyone used the Parallax (actually Grayhill) 4X4 matrix keypad.
> If so, can you tell me how many pins I would need to interface it to
> the BS2? Are there any sample programs out there? Is there a
> different kind of keypad that only uses one wire for communication
> instead of a bunch like this one may use?
Depends on what you want the matrix to do. Just to light LEDs it would take
8 I/O lines. For something heavier duty you might want to use a 595 shift
register or maybe a TPIC6595. Both take 3 I/O lines, I think.
Sid
    edited 2004-06-17 19:19
    Chris
    edited 2004-06-17 21:18
    <Jon's Standard Reminder On>
    Yes, check the Nuts & Volts section of our web site.
    <Jon's Standard Reminder Off>
    There are at least a couple articles on keypad scanning.
    -- Jon Williams
    -- Dallas Office
    From: christopher41877 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=kIVm8o8PwWcfTdU1rEUgCHQiKFbQtPBxUF23t4LGvLGuVs84rBJ4w4yqdZwSrPArJUlP1pyuVXu2ucIKJz4Iniy0Wt5D-Qc]CHRIS@R...[/url
    Sent: Thursday, June 17, 2004 1:19 PM
    Subject: [noparse][[/noparse]basicstamps] Parallax 4X4 matrix keypad
    Chris
    Yahoo! Groups Links
    This message has been scanned by WebShield. Please report SPAM to
    abuse@p....
    edited 2004-06-18 01:05
    Chris,
    I have a same question before. You can use MM74C922 as keypad encoder.
    You can go to
    http://www.geocities.com/SiliconValley/Orchard/6633/projects.html
    for the code and schematic.
    It is good, cheap and very easy solutions. The only drawback is that it will
    take 5 I/O pins (comparing with RS232 keypad encoder that uses less pins).
    Bronson Alex
    Sent: Friday, June 18, 2004 1:19 AM
    > Hi,
    > Thanks,
    > Chris
    > Yahoo! Groups Links
    edited 2004-06-18 16:32
    > CHRIS@R... writes:
    keypad.
    to
    communication
    would take
    595 shift
    > Sid
    Keypad = input = 74HC165 and 3 lines
    2 units would handle 16 inputs (4 x 4=16 butttons on the keypad) so
    a pair of 165's *could* handle a 4x4 keypad. I don't have the code
    and have not tried to use these, but I just wanted to review the
    possibility.
    Dave
    Chris,
    I used 5 BS2 pins to control '595 and '165 shift registers.
    I only used 4 output and 4 input, so I still have 4 output and 4
    inputs left over. Typically, this would have taken 8 pins (4 output
    and 4 input) if done in classical textbook approach.
    Below is the code I used.
    '{$STAMP BS2}
    '{$PBASIC 2.0}
    CLK CON 0 'pin 11 of 595, pin 2 of 165 orange
    D595 CON 1 'pin 14 of 595 purple
    CS595 CON 2 'pin 12 of 595 brown
    D165 CON 3 'pin 9 of 165 grey
    CS165 CON 4 'pin 1 of 165 white/red
    db VAR Bit
    press VAR Bit
    press = 0
    key VAR Nib
    keys VAR Byte
    Row VAR Nib
    Col VAR Nib
    pattern VAR Byte
    switches VAR Byte
    LOW CS595
    HIGH CS165
    Again:
    pattern = %00000001
    GOSUB Keyscan
    IF press = 0 THEN Again
    DEBUG "Key pressed = ", DEC Keys & %00001111, CR
    press = 0
    GOTO Again
    Keyscan:
    FOR row = 0 TO 3
    SHIFTOUT D595, Clk, MSBFIRST, [noparse][[/noparse]pattern]
    PULSOUT CS595, 1
    PULSOUT CS165, 1
    SHIFTIN D165, Clk, MSBPRE, [noparse][[/noparse]col]
    key = NCD col
    IF key <> 0 THEN push
    pattern = pattern << 1
    NEXT
    db = 0
    RETURN
    Push:
    IF db = 1 THEN Done
    db = 1
    press = 1
    keys = (row*4) + (key-1)
    LOOKUP keys, [noparse][[/noparse]1,2,3,10,4,5,6,11,7,8,9,12,14,0,15,13], keys
    Done:
    RETURN
    --- In basicstamps@yahoogroups.com, "christopher41877" <CHRIS@R...>
    wrote:
    > Hi,
    keypad.
    to
    > Thanks,
    > Chris
