Hardware not found when using laptops
I also have had probs with laptops in the past and have found that
the problem is usually to do with some sort of built in pointing
device, eg mouse touch pad that sort of thing and have found that if
you plug in a standard ps2 mouse it releases the resourses ie com 1
that you need to connect to your basic stamp when you want to use
your touch pad ect again just reboot with the ps2 mouse removed.
