Seven segment display drivers
Hi:
I'm hoping to drive a six digit seven-segment display with my basic
stamp II. The MAX7219 seems to do extactly what I want, but it's a
little expensive and doesn't seem too easy to find.
IS there a cheaper alternative?
DmACQ
DmACQ
>Hi:
You might have a look at our EDE707 IC. It is around 15% less expensive
that the MAX part and in stock. Up to 8 digits with counter functionality
also. Datasheet at www.elabinc.com
-Todd Peterson
E-Lab Digital Engineering, Inc.
www.elabinc.com (816) 257-9954
alternative.
-- Jon Williams
-- Dallas Office
From: dmacq1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=WnFM5a6MP_c0ZhTC3WF8nAqdpOmeuA8aR-ZS6SCkGLsS6yh3aim6MM6DinWd5Hm42Uj2IC_b1nKb]dmacq@i...[/url
Sent: Monday, June 14, 2004 2:37 PM
Subject: [noparse][[/noparse]basicstamps] SEVEN SEGMENT DISPLAY DRIVERS
Hi:
little expensive and doesn't seem too easy to find. IS there a cheaper
alternative?
DmACQ
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
anode or common cathode?
If the unit has a common anode or cathode........I have been looking for a 5
digit seven segment display, you mentioned you want to drive a 6 digit
display.
Who is the manufacturer?
Ken
Hi:
DmACQ
Thanks for your thoughts.
With any luck I'll be making a lot of these things so I'm trying to keep the parts (and
the
hole-drilling to a minimum.
But what you suggest may be a good way to start.
macQ
> I believe 6 x 74HCT595 could be used to drive such
> a display -- with more programming than the 7219.
> I thought Jameco, JDR Microdevices, or certainly
> Maxim-IC would have these.
> --- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> > Are wiring up 6 individual 7 segment displays or does the unit have
> a common
> looking for a 5
> digit
> > display.
> > Ken
> > Hi:
> > DmACQ
> from the same email address that you subscribed. Text in the Subject and Body of the
> Yahoo! Groups Links
the
The price of the 6276 is right though.
And I liked your clock.
macQ
> Hi DmACQ:
> The Allegro 6276 is about $2 each IC in small qty. Serial input, DC LED
> drive with adjustable drive current makes for BRIGHT displays, and
> there's no limit on the number of digits. Up to 90 ma per LED with an
> total for the chip just under 1.5 Amps against a LED supply voltage of
> 17 Volts max, good for all LED colors or series LED connections like are
> used in large 7-segment digits. Each 6276 has 16 current sinks that
> can be used to drive 2 each CA 7-segment digit + d.p., 1 each CA
> alphanumeric LED character (with a couple of unused pins), or 16
> individual LEDs. So for a 6 digit display you need 3 chips for under $7
> total in small quantities. See:
> http://www.allegromicro.com/sf/6276/
> A 6 digit clock I made at:
> http://www.pacificsites.com/~brooke/LED1PC2.shtml
> Have Fun,
> Brooke Clarke, N6GCE
> http://www.PRC68.com
> >Date: Mon, 14 Jun 2004 19:37:28 -0000
> > From: "dmacq1" <dmacq@i...>
> >Subject: SEVEN SEGMENT DISPLAY DRIVERS
> >Hi:
> >DmACQ
> Yahoo! Groups Links
Know of any software written to drive two of the MC14489s?i
> They are stackable, just like the MAX7219 -- and much easier to come by.
> -- Jon Williams
> -- Dallas Office
> From: dmacq1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_5MX9Y3FThVMHx9u6onmKQO4lT80CX-mtJ20cODV9mcQlenyYu50ejZkE3mVxKYvqeXXMfW1uCC_]dmacq@i...[/url
> Sent: Tuesday, June 15, 2004 12:29 PM
> Subject: [noparse][[/noparse]basicstamps] Re: SEVEN SEGMENT DISPLAY DRIVERS
> Hi Jon:
> That is a good alternative -- too bad it only drives five digits though.
> Thanks for your help.
> Cheers
> MaCQ
> In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...> wrote:
> > While not a direct replacement, the Motorola MC14489 is a viable
> > alternative.
> > -- Jon Williams
> > -- Dallas Office
> > From: dmacq1 [noparse][[/noparse]mailto:dmacq@i...]
> > Hi:
> > DmACQ
> > Yahoo! Groups Links
> > abuse@p...
> Yahoo! Groups Links
> abuse@p....
> Yahoo! Groups Links
a common
looking for a 5
digit
> display.
> Ken
> Hi:
> DmACQ
Have Fun,
>Hi:
>DmACQ
Interesting product, nice price.
The large number of transistors seems a little daunting though,
particualrily since I may need to make a number of these things.
MacQ
In basicstamps@yahoogroups.com, Todd Peterson <toddp@e...> wrote:
> At 07:37 PM 6/14/2004 +0000, you wrote:
> >Hi:
expensive
functionality
> -Todd Peterson
Hi Jon:
Cheers
MaCQ
> alternative.
> -- Jon Williams
> -- Dallas Office
> Hi:
> alternative?
> DmACQ
> Yahoo! Groups Links
> abuse@p...
-- Jon Williams
-- Dallas Office
From: dmacq1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3eIrVmyta86nBZBVdzPiMB9SuIG5rtq4MusJ-Ov3uzUFde5d7Z5VlpSkJkC6PP8Gfwbx6_jwk3Q0U54aAA]dmacq@i...[/url
Hi Jon:
Cheers
MaCQ
> alternative.
> -- Jon Williams
> -- Dallas Office
> Hi:
> DmACQ
> Yahoo! Groups Links
> abuse@p...
Yahoo! Groups Links
abuse@p....
shouldn't be that hard.
-- Jon Williams
-- Dallas Office
From: dmacq@i... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wTpfgCR7gNFrSB05Gi-oDq9GMincUmey29j-p7QJvPCqO79Kwg9SvQWBAwfueoJKg_3v2rYefCGkWw]dmacq@i...[/url
Sent: Tuesday, June 15, 2004 9:10 AM
Subject: RE: [noparse][[/noparse]basicstamps] Re: SEVEN SEGMENT DISPLAY DRIVERS
Well, maybe I should consider that, the price is very attractive. Know
> -- Jon Williams
> -- Dallas Office
> From: dmacq1 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wTpfgCR7gNFrSB05Gi-oDq9GMincUmey29j-p7QJvPCqO79Kwg9SvQWBAwfueoJKg_3v2rYefCGkWw]dmacq@i...[/url
> Hi Jon:
> though. Thanks for your help.
> Cheers
> MaCQ
> > alternative.
> > -- Jon Williams
> > -- Dallas Office
> > Hi:
> > DmACQ
> > Subject
> > Yahoo! Groups Links
> > abuse@p...
> Yahoo! Groups Links
> abuse@p....
> and Body of the
> Yahoo! Groups Links
Yahoo! Groups Links
abuse@p....
