usb power? (on mac)
hey all,
does anyone know if you could set up a stamp to use power from the usb
jack instead of a 9 volt on a mac? anyone tried this?
thanks,
matt
thanks,
matt
Cut the cable open.
The two biggest wires are the power supply.
I have one where Red = + and Black = -
Regards
ECO
Sent: Monday, June 14, 2004 11:05 AM
Subject: SV: [noparse][[/noparse]basicstamps] usb power? (on mac)
> Greetings!
> Yes it should be doable.
> I don't remember which pin is what, but one of the pins is Gnd, and
> another is +12V
> So get a cable, cut it open and measure.
> Then add a decent 5V regulator (A 7805 and couple of caps) and you
> should be all set.
> As a matter of fact, some people mount relays on this connector, to
> switch on/off their monitors as this pin gets power as soon as you
> switch the computer on.
> Trygve
Opprinnelig melding
> Fra: Matt Gilbert [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=VAYovUPJuTfXnamDHzw0vCJb_nYQauWVDiwG-iIrAbOQFfZyGQBS88Lv3nv6irg1k8kLGLiARDiQxZI]gilb_jm@y...[/url
> Sendt: 13. juni 2004 19:05
> Til: basicstamps@yahoogroups.com
> Emne: [noparse][[/noparse]basicstamps] usb power? (on mac)
> hey all,
> thanks,
> matt
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
> Yahoo! Groups Links
> from the same email address that you subscribed. Text in the Subject and Body of the message will be ignored.
> Yahoo! Groups Links
Cut the cable open.
Regards
ECO
> Greetings!
> another is +12V
> should be all set.
> Trygve
Opprinnelig melding
> Fra: Matt Gilbert [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Z2frZazfJ2J3v9QskFK8rYlBGT1kOXJRm5QSs9VzNzlnkcOGQgV0TOCM5Fx6T_7wr-xoKsFzm9w]gilb_jm@y...[/url
> hey all,
> thanks,
> matt
> Yahoo! Groups Links
> Yahoo! Groups Links
the power is +5V, not +12V. Every cable I've ever cut has red for +5 and
black for ground and I solder a 2 pin female header on it and that's 5V.
Al Williams
AWC
*Easy RS232 Prototyping
http:/www.awce.com/rs1.htm
From: Trygve Henriksen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RbPU_3Els9xSg6dJSHDunpenphI0C4vPNI26_1kPtrZq6x4ECj0BaJGxKziTY9pWzIouZ-eOTyftCg-tbv7hbWtAc4s]trygve.henriksen@v...[/url
Sent: Monday, June 14, 2004 4:05 AM
Greetings!
I don't remember which pin is what, but one of the pins is Gnd, and another
is +12V So get a cable, cut it open and measure. Then add a decent 5V
regulator (A 7805 and couple of caps) and you should be all set.
As a matter of fact, some people mount relays on this connector, to switch
on/off their monitors as this pin gets power as soon as you switch the
computer on.
Trygve
Opprinnelig melding
Fra: Matt Gilbert [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RpXYfgGTndAtcQi6djQRJS6Cf0c9GW1dS5d6jHWALtz0czA7ZmuLS_aOWDsyrzDUtfJGTx4tGdHCO2i5]gilb_jm@y...[/url
hey all,
thanks,
matt
Yahoo! Groups Links
Yahoo! Groups Links
> I don't know about the mac, but I do this all the time on the PC.
However,
+5 and
that's 5V.
> Regards,
> Al Williams
> AWC
The thing I mentioned last week is that the USB will deliver power
and it will drop voltage as you increase your load. Laptops will
offer a much weaker maximum ouput that a desk Mac.
Figure out your needs, connect a load and watch the voltage drop. as
you increase your load to some value, you'll see a voltage drop and
you'll know you have reached the limit for that machine.
Dave
