usb power? (macintosh)
Hi all,
Does anyone know if it's possible to use the power from a usb port on
a macintosh (using a keyspan serial adapter for the stamp) to power a
basic stamp device?
Just wondering.
Matt
basic stamp device?
Just wondering.
Matt
> Hi all,
on
a
> basic stamp device?
> Just wondering.
> Matt
The spec for the USB is on the order of 500mA. Check your project
and see what the max will be.
I would measure the voltage CLOSELY and keep adding a load until
there was a voltage drop of about a half volt. Whatever that load is
would be about the edge of the cliff load.
I am not well versed in USB, but the specs on the parallel port call
of a load and voltage. is: 2.5 volts at a 2.5 mA load.
That means to meet the spec, you could start with 12 volts, just so
long as there is still 2.5 volts when there is a 2.5mA load.
What that means to you is that the voltage MAY NOT be 5.0000 volts,
but may be 6 or 7 or something.
Hope that is a starting point.
But, I think some testing of the available current is in order.
Dave
