Watchdog on BS2?
Although I did not make the original post, It would be nice to have the
watchdog do what a watchdog does.....As you already know, if the watchdog timer
"times out" before being periodically reset by program instructions, cause the
program to start over from the beginning.
But on the other hand, the Stamps seem to be extremely robust and user error
in the code is about all I have seen make the program hang up...ie, never
ending loop.
my 2cents
Ken
The watchdog inside the PIC or SX used in BASIC Stamp modules is not
accessible via PBASIC. Since you just learned about the watchdog, was
is it you'd like to do with it?
-- Jon Williams
-- Dallas Office
ending loop.
my 2cents
Ken
-- Jon Williams
-- Dallas Office
For example if the weigh data stops working, the result is not catostrophic,
it is?. A watchdog would indeed be needed (desired) if a micro controller was
controlling some process where the result of the the micro no longer
processing data would cause catostrophic event, like something catching on fire etc.
On the other hand, in theory you could build a watchdog into your program
using external hardware.
My idea would be to use a re-triggerable one shot multivibrator. Have the
stamp retrigger the multivibrator often enough to keep the output in one state,
high or low.
You would interface the high or low signal to the reset pin of the stamp
(with a pull up on the stamp reset pin). Some trick would be needed to make sure
the multivibrator does not hold the reset low while the stamp is attempting to
"wake up" or start....that would not be to hard.
If the stamp program stops running, the multivibrator times out and causes
the reset pin on the stamp to go low, and resetting the program same as pusing
the reset button.
Jon Williams, in theory this should work, shouldn't it?
Ken
Recently I just finished my first commercial project using BS2.
The project is to control Batching Plant and taking 2 serin from electronic
scale for batch weigh data, but no watchdog.
My friend said that when we use microcontroller for industrial process, it
is vital to use watchdog.
What I need to do is to apply watchdog in my project to monitor whenever my
program hangs.
If that happens, the watchdog will reset my program automatically.
Also, what kind of conditions can make microcontroller to hang?
Bronson Alex
My friend said that the PIC controller on my BS2IC has 'built-in' watchdog, is that true? How can I access the watchdog?
If it is not true, where should I start to learn more about watchdog?
(I just knew the meaning of 'watchdog' yesterday).
Bronson Alex
-- Jon Williams
-- Dallas Office
From: ALTRAMAN [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=LQ5syy0G1okw5Yz1dBRC4FWKW1RHUP0YjfbqByKj9wZotUML0FIcmDWZHK9s6fmWVv78xb1lAiwnNXPLgWM]altraman@d...[/url
Sent: Wednesday, June 09, 2004 8:19 PM
Subject: [noparse][[/noparse]basicstamps] Watchdog on BS2?
How can I have Watchdog on my BS2?
If it is not true, where should I start to learn more about watchdog? (I
Bronson Alex
program hangs.
Bronson Alex
Sent: Thursday, June 10, 2004 8:28 AM
Subject: RE: [noparse][[/noparse]basicstamps] Watchdog on BS2?
> -- Jon Williams
> -- Dallas Office
> From: ALTRAMAN [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=djtv4mR1njCaJg3rhOVTyzvzD5AvjkI1ymIIKPN76sLnfHjig_4NVldA2MbQwg8Tx2kWuYE2cY6P6WA]altraman@d...[/url
> Regards,
> Bronson Alex
> Yahoo! Groups Links
England who loves the old 555 for this) that the BASIC Stamp will
constantly reset. If your program gets stuck and doesn't get around to
resetting the 555, its output can be used to reset the BASIC Stamp.
What conditions will cause the micro to hang? Well, the BASIC Stamp has
been around long enough that we're pretty certain it won't hang without
your direct involvement, that is, a bad piece of code or code that waits
on a input that never comes, etc.
-- Jon Williams
-- Dallas Office
From: ALTRAMAN [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OlyKXexMd7qaT22iqyQQnjvgO43Pi74oGSoqljza_1aapJbrtTIjv5Q-KUasAuYjK56J7kZKEhIBCLonPqQ]altraman@d...[/url
Sent: Wednesday, June 09, 2004 8:46 PM
Subject: Re: [noparse][[/noparse]basicstamps] Watchdog on BS2?
Recently I just finished my first commercial project using BS2. The
scale for batch weigh data, but no watchdog. My friend said that when we
use microcontroller for industrial process, it is vital to use watchdog.
my program hangs. If that happens, the watchdog will reset my program
automatically. Also, what kind of conditions can make microcontroller to
hang?
Bronson Alex
> -- Jon Williams
> -- Dallas Office
> watchdog, is that true? How can I access the watchdog? If it is not
> true, where should I start to learn more about watchdog? (I just knew
> Regards,
> Bronson Alex
> and
> Yahoo! Groups Links
Yahoo! Groups Links
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
must admit using a 555 as an auto-reset or watchdog is a pretty good idea.
Another use for it is a auto-power off feature to kill power after so long
without no activity
At 10:15 PM 6/9/2004, you wrote:
>I think for your application the watchdog would be nice but is not critical.
>fire etc.
>state,
>high or low.
>make sure
>attempting to
>pusing
>the reset button.
>Ken
>program hangs.
>Thanks,
>Bronson Alex
>Yahoo! Groups Links
I will try to use 555 to implement watchdog in my application.
Bronson Alex
Sent: Thursday, June 10, 2004 10:15 AM
critical.
catostrophic,
was
fire etc.
state,
> high or low.
make sure
attempting to
pusing
> the reset button.
> Ken
electronic
my
> program hangs.
> Thanks,
> Bronson Alex
> Yahoo! Groups Links
